Tip & How-To about Cell Phones
Charging problem on mobile phone - try this first
If you are getting problems with your charger not fitting properly our being loose in your phone, try cleaning out the socket in the phone with a fine needle. i got lots of fluff and even pieces of sawdust out of mine. Turn the phone off first.
Cell Phones Logo
my galaxy 3 phone will not charge properly how do i fix it
Charging issues is a process of elimination. First the charger....many chargers will fit but not all that fit will work. A bluetooth charger will fit but would never charge your battery completely. Make sure you are using a proper charger. 2nd is the charging port on the phone. If the charger is loose it could be a bad port or the prongs on the charger are not holding....is it loose? Or if there is corrosion on the port. If corrosion, clean with alcohol and tooth brush. 3rd is the battery. If its swollen, then it's toast. A li-on battery will start to decrease after 400 to 500 charges.
Jun 18, 2014 | Samsung Galaxy S 4G Cell Phone
phone not charging ways to fix
Your phone could fail to charge for a number of reasons. 1. Check all connections -- charger to phone, battery within phone (did you drop it recently?) charger to wall socket, etc. Make sure connections are clean and well-fitting. 2. Make sure your battery is IN your phone, or that the back plate isn't loose letting the battery wiggle. 3. Has the phone been damaged by electricity or water? How old is the battery? If all else fails, take the phone to a battery store. They can test the battery and tell you whether the battery has failed, and sell you a new one that sshould charge, or whether the phone is kaput.
Feb 01, 2014 | Computers & Internet
i am using sony ericsson z550i it is not getting charge can u plzzz give me a solution
Dear,
first of all try cleaning the pins of your charger and mobile charging socket with petrol or kerosine oil.
then see if it works,
if still the problem persist, then their may be the fault in your charger or mobile charging socket. Or electric socket where you put your charger for charging!
try charging your mobile by putting your charger in different switch board, if still it wont work, then try charging your mobile with different charger, if your mobile is getting charge, then get sure that problem is in your charger,
its time to buy a new charger.
original charges cost=900
duplicate charges cost=100
regards!
Aug 17, 2011 | Sony Ericsson Z550i Cellular Phone
not charging
Why is it not charging?
Does the charger you are using not fit the phone?
Is the electricity on?
Does the charger fit the socket?
Try another socket
See if the charger really fits the phone
Jun 13, 2010 | Nokia 1100
my motorola w375 will not charge suddenly
this can happen if the charger is drained internally or gets leaked due to over charge.also if the pins of the charger gets crooked or loose .also if the socket in the phone where you insert the charger if that socket of your phone is dirty it will stop charging.in that socket there is a round mettalic connector if that mettalic thing gets loose from the phone this can hasppen.also try changing the charger and check out first before taking the phone to the repair center. new charger caB BE AVAILABLE AT. www.radioshack.com websites/.
Jan 06, 2009 | Motorola Mobility W375 Cellular Phone
830 people viewed this tip
Top Cell Phones Experts
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
