Tip & How-To about Seagate Computers & Internet
HOW TO RETRIEVE A PASSWORD FROM, OR CHANGE THE PASSWORD ON A WIRELESS ROUTER
How to retrieve a password or change the password for a wireless network from the router
Get an ethernet cable and plug your computer to the router with it..Click on your browser and in the address bar type the IP address for your particular router. (You can find this by googling the make and model of your router and the words IP ADDRESS.)
you will then be presented with the page after which you will have access to the router's control software. The page asks for username and password, they should, if they have not been altered from default, both be the word admin
Having entered these and pressed the enter button you should be in the control menus. Look for the wireless networking option, find it , click on it and you should find yourself in a screen on which your network's ID, (also known as SSID,) and password are displayed.
There may or may not be the option of turning the radio / wireless section off
temporarily...if it is available click on it to stop the wireless from broadcasting...if the option is not listed it obviously cannot be done!
Next, highlight the network password and delete it, then insert your new password, making a note of it and remembering that it will be case sensitive.
Make sure you SAVE THE CHANGES
Next ... If you have shut wireless/radio down reactivate it.
Then exit the utility.
Advanced users might want to create a password for getting into the router.
Anyway,after having exited detach the ethernet lead and click on your browser and click on the wireless networking/connection icon in the system tray, highlight your network and click on the connect button. You will then be presented with the option of entering your new password which should be entered exactly as you wrote it when in the router. You should, after a wait of a few seconds, be connected to the internet. Hide the new password and your ethernet cable if you have not put a new admin password on the router.
Then, BOBS YOUR UNCLE.
Computers & Internet Logo
How do I change my password
You should access your router's setup using your Installation CD and follow the required steps.
Jul 24, 2015 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Why can't I get it to connect?
Get an ethernet cable and plug your computer to the router with it..Click on your browser and in the address bar type the IP address for your particular router. (You can find this by googling the make and model of your router and the wordsIP ADDRESS.)
There may or may not be the option of turning the radio / wirelesssection off
Jun 26, 2015 | Computers & Internet
I want to change the password but I can not
I am assuming you mean for the wireless section of your router.
May 19, 2015 | Computers & Internet
how to retrieve password from wireless access point router zyxel -570u
Initial Set-Up
Plug your wireless router into the cable connection in your wall. Plug the connection cord into the "WAN" port on the router. Plug the router's power source into the wall and turn the router on. Connect your wireless access point to your router by pushing one end of an Ethernet cord into the WAP. Push the other end of the Ethernet cord into the "LAN" port on the router. The WAP connects your wireless devices to your router.
Connect your laptop or computer to the WAP. Click the "Start" button on your computer and then click "Control Panel." Click "Network and Internet" and then select "Network and Sharing Center." The "Network and Sharing Center" window opens.
Click "Set up a wireless router or access point." Click the "Next" button.
Follow the prompts to create a wireless pass phrase or security key. Write the key down in a safe location to ensure access later, if required.
Aug 30, 2011 | Zyxel ZyAIR G-570U - Wireless access point...
There are people in my street using my internet. How do i change the network key code to a code of my choice?
  1. Connect your computer to the wireless router. Although you can access the router wirelessly, it is better to use an Ethernet cable to directly connect to your router so that you can securely adjust router settings. Plug the Ethernet cable into the appropriate Ethernet jack on your computer. Plug the other end of the cable into any one of the open Ethernet ports on the back of your wireless router.
  2. Open your computer's web browser. In the URL address field, enter the IP address for your wireless router. This information should be contained in your router's manual. If you cannot find it, enter "198.168.1.1" as the address. This is usually the default IP address for most routers.
  3. Enter the username and password for your router. This should also be supplied in the router's manual. If you don't have this information, go to routerpasswords.com and find the brand and model of your router. This site lists the default login information for most wireless routers.
  4. You should now be able to see your wireless router settings. You can configure your network ports, as well as SSID (wireless network name) and passwords.
This FREE Tech support is provided by volunteers--If this was helpful, please indicate so, if not -comment back so we can dig further to resolve this.
Dec 30, 2010 | Computers & Internet
1,628 people viewed this tip
Top Seagate Computers & Internet Experts
Computer Links
Steve
terminalcon
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
