Tip & How-To about Android Apps
How to increase processor speed of a rooted android phone
For most smartphones, the processors are clocked at speeds much lesser than their maximum supported speeds to improve battery life. That also means you are not enjoying all the juice your phone can give you.
Lets see how you can overclock your android phone to unleash its full potential.
Important: Overclocking requires super user permissions and so your phone needs to be rooted.
SetCpu is the best app out there to overclock your android phone. Its sheer simplicity and useful options sets its apart from its competitors. You can either download it as a paid app from the Android market or simply download the zipped apk from XDA forums.
Using SetCpu. Once you install and start SetCpu, it will first show you a screen with two options. Unless you have a specific reason to do otherwise, simply select "Autodetect Speeds Recommended".
A screen will come up where you can change the maximum and minimum clock speeds and select the scaling method. SetCpu will automatically detect the maximum clock speed your processor supports.
Max - maximum clock speed.
Now its a bad idea to rush and drag the slider to its maximum in one shot. Although there will be no problems for most phones, it could lead to instability for some. Instead, try increasing the clock speed in small steps, running some heavy apps like games and if you don't see any instability, go back and repeat with increasing the clock speed. In case you find your phone going unstable at any speed, just set the speed to slightly below that value.
Min - Minimum clock speed.
Minimum frequency is the speed at which your phone will run when it is idle or no heavy apps are running. Setting it to a too low value can cause your phone to go slow with incoming calls, alarms and any other app that runs while idle. Generally it is advisable to set it to at least one third of the maximum speed your phone processor supports.
Scaling.
The scaling option determines how aggressively the minimum and maximum clock speeds will be applied. The drop down menu gives 5 options as below -
  1. OnDemand - Automatically sets the minimum and maximum based on load. This is the recommended setting.
  2. Conservative - Very similar to OnDemad except that the scaling is less rapid.
  3. Powersaver - Makes your phone run at min speed always to give maximum battery life.
  4. Performance - Makes your phone run at max speed always.
  5. Userspace - This option is useless as of now and is kept as a future option for apps to change clock speed that SetCpu doesn't use.
Once your phone looks comfortable with the new frequencies, you can use the "Set on Boot" option to enable the settings permanently.
Tutorial Video:Overclock Your Android Phone to Unleash its Full Power
Download link: http://forum.xda-developers.com/attachment.php?attachmentid=648354&d=1310073004
Android Apps Logo
hoe to improve iphone 3g processing speed... it is so lazy and waste my time too
You cant increase the 3g processing speed if your iphone is stock.
Its possible to increase it if your iphone is jailbroken.
Right now the 3g has a processor speed of 412mhz which is pretty slow on todays standards. Most phones now are 1ghz to 1.8ghz.
Even if you jailbroke the phone. The maximum that u could increase the processor speed is to 550mhz. Downside is that when you increase the processor speed past its stock mhz, the battery will die faster.
Aug 08, 2013 | Cell Phones
hi im working here in the middle east i have a defective acer aspire 4741, processor is still ok and other pheriperals i want to use it as a desktop which motherboard brand mini itx, with pga 988 bga 1288 socket for core i3 m350 cpu can you suggest ? thanks
The Core i3 targeted to laptops can use three different pin-outs, PGA988, BGA1023 or BGA1288. They carry the same main features as socket 1156 models: integrated DDR3 dual-channel memory controller the maximum supported clock rate depends on the CPU, models that support DDR3 memories up to 1066 MHz also support 800 MHz memories ; integrated PCI Express 2.0 controller supporting one x16 lane or one x8 lanes, and DMI bus.
The main difference between laptop and desktop models is the clock rates: in order to save battery life, laptop models have a far lower nominal clock rate.
Referring to pin-outs as stated above the socket you are looking for is specifically designed for laptop, desktop pinouts for first generation icore series are sockets 1156 and 1366. for second generation icores socket 1155. In my opinion you need your laptop motherboard repaired or replaced.
Hopefully this information helps.
Thank you for using FixYa.
Aug 03, 2011 | Intel CPU MOBILE COREI5520M 240G 3M PGA988...
can an external memory harddrive can make the speed of my computer faster,if it can what are the specs of hard drive do i get?
The speed of you PC depends on the clock speed of the processor and supported by the Random access Memory - internal memory - that supports the processor which is the CPU- central processing unit.
So unless this is improved it wont make a difference. However keep you PC with low load of programs and clear of any virus and unnecessary files that might bring the speed lower
Jan 24, 2011 | Dynex External USB 2.0 Multiformat Memory...
Athlon processor upgrade assistance:
Go to this link:
http://us.msi.com/?func=searchresult&keywords=ms-7025
Select the model motherboard you have and click on the CPU support link, it will show you a list of CPU's that are supported. You have a socket 939 board and AMD CPU's are now AM2, AM2+ and AM3 socket, which are 940 pin. It may be difficult to find a new CPU for your motherboard that is new since they have not been made in awhile.
Feb 09, 2010 | EliteGroup MB ECS 741GX-M SIS741GX 462...
366 people viewed this tip
Top Apps Experts
Are you an App Expert? Answer questions, earn points and help others
