Tip & How-To about Android Apps
How to fake your android device gps location to any place you prefer(rooted phones only)
1. Install the app Fake gps from playstore (or just google it)
2. set the pointer to any location on earth (you can also type manually the coordinates).
3. select the "set GPS Location" button.
3.Your gps location have now been faked and this fake location will be accessible to all the messengers and other apps you are using. https://play.google.com/store/apps/details?id=com.lexa.fakegps
Android Apps Logo
how do I re install google play on my android
If you mean the Google Play Store, you can download the .apk file from sources such as
http://earth.androidapksfree.com/venus/com.android.vending-v5.4.12-80341200-Android-2.3.apk
(find links for the latest version at http://www.androidapksfree.com/apk/google-play-store-apk-latest-version-download/ )... then transfer it to your device using a USB cable connected to your computer (put it in the Downloads folder).
In your device's Settings, go to Security, then put a check next to 'Unknown Sources' which allows apps to install from a local .apk file. Next, use the MyFiles app to go to Recent files. Find the com.android.vending-[version].apk file, click on it, then follow the prompts to allow it to install.
Once it's finished installing, go back to Settings->Security and UNcheck the Unknown sources option again (you don't need that checked to install apps from the Play Store).
Apr 07, 2015 | Android Apps
Had to do factory reset, now unable to download apps from google playstore like youtube etc, any help?
I suggest that you troubleshoot first, instead of a hard reset. Factory reset is within settings.
If any google app won't download nor install, it's probably because your google services are not updated or is corrupted. Try the next steps before factory reset.
1. Go to settings, scroll down to app.
2. From here search for PlayStore and tap it.
3. Tap Clear Cache and Clear data.
4. Go Back.
5. Search now for Google services, this one is not under the download tab, which you can notice at the top of the screen, instead got to All and scroll down until you find it.
6. Tap Clear Cache and Clear data if available.
7. Reboot phone or tablet.
Most of the time this procedure do work, some people also opt to remove the google account and sign in after the reboot.
After the boot, open the PlayStore, accept the agreement and try to download anything from the PlayStore that is compatible with your tablet. Also, just to be sure, go to settings, security, look for Unknown Sources and enable it. This feature allow you to install any apk file that is not from the PlayStore.
Mar 07, 2015 | Tablets & eReaders
my galaxy s5 has been stolen and the person who took it turned off gps how do can i turn back on remotely
Go to PlayStore and install Teamviewer, once the device is connected to internet the app will install it self. If it ask for any info for the set up, go head. Now download Teamviewer in your computer and use the same log in information from the Teamviewer that was downloaded from the PlayStore. With this app you can have remote control over your lost device even with GPS off. I hope it works and good luck.
Feb 08, 2015 | Cell Phones
How do I install apps without playstore?
Google the app name and put .apk at the end of it then download it then you can install it once u lyophilized locate it on your phone some phones you have to go to settings and allow unknown source or somthing like that
Oct 04, 2014 | Cell Phones
687 people viewed this tip
Top Apps Experts
Are you an App Expert? Answer questions, earn points and help others
