Tip & How-To about Samsung RF267AERS French Door Refrigerator
Ice door keeps opening on samsung fridges
Look at the pic below. The board you will be replacing is number 31.
The part number is DA41-00651M. They cost about 130 dollars and it will take care of your problem.
You will have to unplug the unit, remove the old board and install the new board. Before you attempt anything, make sure you read the instructions completely and follow them exactly.
It will tell you how to reprogram the unit when the task is complete.
It has a stuck processor that cannot be reprogrammed or replaced. This is an issue that Maytag would send you the board for free on but I don't know if Samsung will do that on this unit.
Samsung RF267AERS French Door Refrigerator Logo
bearring replacement cost on a 2001 jaguar s type
42 dollars, 31 for front go on autopartswarehouse.com
Dec 11, 2012 | 2001 Jaguar S-Type
Toshiba 55SL412U Sound but no picture
Do not replace the board, repair the problem.
Jul 23, 2012 | Samsung LN-S4692D 46 in. LCD HDTV
Ge profile microwave jvm2070. Had led freeze on me now does not take input. Is this the keypad or entire logic board? What is the part number and how much do you think?
As always, it depends on your full model number, but separate parts are not available for the 2070-series ovens, so you would have to order a complete "control panel assembly".
You can find handy exploded views and order parts by model number here. It is reference number 130 on the exploded view.
These run a few hundred to several hundred dollars, depending on the exact model. Our favorite supplier is the Pros here.
It's a pretty simple DIY job.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Then you unplug the keypad (as per the photo below) and move the circuit board into your frame.
Some connectors on the relays may have a lock:
Jun 19, 2011 | GE Microwave Ovens
green light blinks but TV will not come on...nothing
Could be the lamp has gone out. If this is a DLP the lamps are pretty easy to change and cost $130 to $200 dollars. Check the lamp before you toss it out.
Sep 22, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
1,786 people viewed this tip
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Paul
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
