Tip & How-To about Dell Computers & Internet
ERROR CODE 2000-0142 and UNMOUNTABLE_BOOT_VOLUME
Insert your OS disk into your cd/dvd drive
As the machine boots up - it should have an option to hit F2 or F12
Hit the F12 key
This will give you the option of where to boot your machine from.
Select boot from CD/DVD drive
For me windows loaded some files and gave me an option to either install windows or repair.
I selected repair
I was then asked for the admin password -- typed it in.
It brings you to a command prompt :
Type in CHKDSK
or
Type in CHKDSK/R
Hit the ENTER key
Once your machine has finished and repairing the hard drive, type EXIT and press ENTER to restart your laptop.
PRESTO THE DELL LAPTOP IS NOW BOOTING UP AND IS NOW HAVING ALL ITS DATA BACKED UP.
I have also found another command that could be tried if the above fails. Bear in mind, i didnt have to do it, but will post it here anyway.
After the command prompt - type in FIXBOOT
According to the DELL website the error code 2000-0142 is a Drive Self Test failed error code. http://support.dell.com/support/topi...ED2&doclang=en
This has worked out for myself and i do hope it works for you.
Computers & Internet Logo
My lenovo thinkcentre desktop computer never shows "press any key" while I try to format. Unable format my C drive and recently 500 GB HDD was installed in my computer. pl.advise how to format it.Despite pressing key F1.F2,del,esc,ctrl+atl+esc but no use.there is no booting.pl advise.
Hi! Welcome to www.fixya.com.
Removed your power cable and drain power without any power. restart and keep on hitting f12 to get to the boot menu choose ODD then put the OS CD then press enter until its say press any key. If it did not work your other option is reboot and hit f1 or f2 to change the boot sequence on boot option. Restart pc then hit f2 go to boot option and choose DVD/CD to be your first boot option then press f10 restart and it should load automatically.
Hope this resolution fix the problem on your computer. Thanks for contacting Fixya. Bye for now.
Jul 20, 2011 | Computers & Internet
windows 7 laptop won't boot to OS , only has a black screen with a blinking cursor
Insert your system recovery disc to repair your startup.
1. Change your Bios to boot from disc:
When your computer powers on, hit F2 (on some computers, F8 on others). Use your arrow keys and move to the right to your BOOT option. Hit the down arrow until you select your CD/DVD drive. Look at the bottom of your screen, and it should say to change the option hit F7 or F8. Use the specified keys, and move your CD/DVD drive above your hard-drive. Save your settings.
2. Boot from your disc. Insert your system recovery disc and restart your computer. Let the recovery disc load. If the option comes up to hit any button to boot from CD/DVD, then hit any button. Once it loads, it should come to a spot where it wants your language. Select your language, then select the option "Startup Repair". Click on it, and let it repair the startup. If it automatically starts correcting your startup then great! If not, then select your operating system from the list and click the Repair Startup option. Restart your computer, and hopefully it will boot from your hard-drive correctly.
Hope this works.
P.S. If it continues to boot from your recovery disc, then using the same method in step 1, go to your bios, and move your CD/DVD drive below your hard-drive.
Mar 01, 2011 | Computers & Internet
I am getting the message error code 2000-0142 on my inspiron 1525. Does this mean the hard drive needs to be replaced and if so, was it something I did? It was working fine in the morning and then in the afternoon when I tried to start it up I got the black/blue screen.
If reseating your hard drive doesnt fix it, Insert your Windows disk into your cd/dvd drive
As the machine boots up, hit the F12 key
The disk loads some files and gives an option to either install windows or repair, select repair and boot onto Windows (select 1)
Type in CHKDSK/R
Hit the ENTER key
Jan 09, 2010 | Dell Inspiron 1525 Laptop
my acer aspire 5315 always show boot prepare os. When i want to install windows it cannot show cd boot (booting from cd/dvd) so i can't install windows. what is the solution sir? thank.
Restart you computer then hit F2 for Boot Bios Setting then GO TO Advance. Change the SATA Mode . ACHE. ot IDE. or Comfatibility.. then enable the F12 boot. make in enable. the hit F10 for save and exit...
Insert you cd os Installer then hit F12 for **** menu. select the CDROOM for boot....
Dec 30, 2009 | Acer Aspire 5315 Notebook
i dont know how to install xp or formatting my pc..can u give me any suggesions?
Put the XP disk in. It should start by itself. Unless you know exaxtly what you want, use the default install.
Mar 25, 2009 | Compaq Presario CQ60-220US PC Laptop
1,972 people viewed this tip
Clive
Clive
Alun Cox
