Tip & How-To about Apple iPhone Cell Phones
How to Extend iPhone Battery Life
This tip will tell you 6 useful tricks to save your iPhone battery life. Firstly, go to check what is draining up your iPhone battery life. On your iPhone(iOS 8), launch Settings App > Scroll down to tap on General > Click Usage, and then choose Battery Usage on Battery column > Scroll down to see which of your Apps were the biggest battery drainers in the past 24 hours, or last 5 days.
1. Turn off Background Refresh for Apps You Don't Use Frequently
Go to Settings > General > Background App Refresh > Tap on the option to disallow all the Apps to refresh their contents when on Wi-Fi or Cellular.
2. Adjust Brightness on Your iPhone
  • Run Settings App.
  • Scroll down to tap on Display & Brightness
  • Turn Off Auto-Brightness by clicking on its option.
  • Adjust the brightness to the low level by swiping to left.
3. Always Keep Background Clean
To close background Apps on iPhone iPad, you can Double-click the Home button to bring up all the Apps running in the background, and then swipe upwards to close them.
4. Auto Lock Your iPhone
Set Auto Lock on iPhone iPad: Settings > General > Auto Lock > Set your iPhone iPad to sleep after one minute of inactive.
5. Clean Up Junks Files on Your iPhone
PhoneClean(http://www.imobie.com/phoneclean/) is a professional iPhone cleaning tool made to remove junk files from your iPhone thus to save battery life, including cache, cookies, temp files, etc.
6. Disable Location Services
  • Run Settings Apps.
  • Scroll down to tap on Privacy.
  • Click Location Services, and then tap on its option to close it.
Top Tips to Save iPhone Battery Life
Cell Phones Logo
I have iPhone 5s (ios 9.2.1) and it has very serious problem about fast battery drainage so what I do??
Usually fast drain can be caused by a virus, many things running like GPS, bluetooth
Feb 18, 2016 | Cell Phones
how to extend battery time for i phone?
Ensure any unneeded apps are stopped and not running in the background. Some apps such as facebook / twitter / etc may need to be completely uninstalled or logged out to keep them from running.
Turn down the screen brightness, Generally turning the screens brightness down till it can still be easily seen but not overly bright can increase cell phone battery by up to 20%
Shut off wifi / bluetooth / gps when not required. Disable Wifi / bluetooth, and GPS will also increase your phones battery time.
Ensure a full charge, most devices (iphones included) usually require a minimum of 8 solid hours to charge, even when they say full, they are not actually "FULL". Make sure your device gets at least 8 hours of charge time before use, and don't allow the battery to drain all the way before the next charge.
Nov 17, 2014 | Apple Iphone 4 - 32gb - Black verizon...
How can I improve my iPhone's battery life?
A recent research conducted on cellphones (smartphones) revealed that most of your battery life is drained by "Internet" and "calls". The more you use your phone for any of these two, the faster your battery drains. Next on the list is "Search for network" which consumes quite a bit of your battery power.
Smaller culprits are WiFi, Bluetooth, Screen brightness, themes, Vibration, etc.
* Reduce screen brightness to minimum
* turn off WiFi/3G/4G when not required (same with Bluetooth)
* if you are out of network area, turn off the mobile network so you cell doesn't keep searching for a network.
* If possible reduce internet usage on your cell phone to improve battery life (ie. if you have a laptop handy, use it!)
* Use a darker wallpaper
* Vibration takes up more battery than ringtones
* use a simple theme
* Dont keep your cell phone charging for long periods (eg. overnight)
* If you plan to buy a new battery, buy a branded authentic one
Hope this helped, thanks for using FixYa!
Apr 11, 2011 | Apple Cell Phones
1,406 people viewed this tip
Top Apple Cell Phones Experts
Computer Repairing
Computer Repairing
Lesley Cameron
Lesley Cameron
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
