Tip & How-To about Stanley Bostitch Rn461 Gun Coil Roofing Nailer
The Best Benefits of Metal Roof Coatings By Conklin
When our white roof coatings are applied to commercial metal roofs you will save money since the frequent local roof repairs will be virtually eliminated. When roof damage occurs from wind and hail storms occur elastomeric white roof coatings are the default choice. In reality Conklin Roofing Systems should be your default choice since they manufacture the best products in the market.
http://roofinghorizon.com/conklin-elastomeric-roof-coatings-austin.html
Stanley Bostitch Rn461 Gun Coil Roofing Nailer Logo
cleaning roof of oven, does the can the element be removed
Oven roof is made up of metal normally and i think Liquid Roof is best for repairing leaks. You should have a look at it.
Liquid Roof AND RV Roof Coatings
Mar 24, 2014 | Bosch HBN 131560B / 131520 hot-air...
mobile home roof
If it's a mobile home he probably has it 2-12 pitch roof I would use roll roofing instead of shingles hope this helps
Jul 04, 2013 | Adhesives, Coatings & Sealants
1988 jayco motorhome class c with water damage on the rear roof area ...trying to repair it &the drivers side ..sidewall ...put new screw covers on side rails & awning rails but not on the roof ....WHAT can I use on a metal roof to seal leaks ...the previous owners ( I just brought the unit) put a white roof coating on the roof but its turned black & its peeling in spots ....What can I use to recoat it to stop the leaks ?
Hi, you can use 6 or 12 inch uncured epdm rubber roofing flashing. it comes in a roll with a protective cover you peel. first clean the area with putty knife, wire brush, orbital sander etc.. use laquer thinner on a rag to with protective gloves and eyewear clean the area well. the uncured is then cut to fit, apply splice adheasive (Lowes) specificly for this job with a 3 inch roller to the area, then apply same to uncured strip. let dry to semi tacky test with finger tips if it doesn't smear its ready. hold strip up and over the area and carefully set it in place. use hand pressure to finish . finally use special lap caulking (lowes) applied to all edges of patch. your done and leak is gone. This uncured rubber is great...it goes over humps, around corners, and once it cures it doesn't come up. ive been in the roofing industry for 35 years and I also am a fellow RVer. and I used this method of repair all the time. this stuff comes in white or black. and can be found at any commercial roofing supply warehouse. good luck
Apr 19, 2013 | Cars & Trucks
how to repair tent trailer roof
Go to an auto parts store and buy a fiberglass kit. Resin, hardener and cloth. Clean and rough the area. apply a coating of mixed resin, then a layer of cloth. Let it dry and repeat a couple of times. After you are satisfied with that get a gallon of Elastomeric, you will find it at Lowes/Home depot. Clean the entire top and apply 2 coats with a brush or roller about 24 hours apart. No rain or moisture for a couple of days. Project complete, water proof roof.
Mar 25, 2009 | Sport & Outdoor - Others
459 people viewed this tip
Top Stanley Air Tools & Compressors Experts
John Trevino
yoopertech
Joe Garcia
Joe Garcia
Are you a Stanley Air Tool and Compressor Expert? Answer questions, earn points and help others
