Tip & How-To about LG Televison & Video
Tv problems lg and vizeo
Power Issues Troubleshooting
*NOTE* LG & Vizio TVs must be plugged in for 5 minutes before it will turn on*
1. Inspect ALL Ribbons and connectors. Any tears or bad connections between boards must be replaced FIRST
2. If you have any of these boards, it should be the first board to be replaced
A) T-Con Board - Video Problems (No Video with standby light on, audio but no video, grainy, distorted, or color problems in screen)
B) X or Y Buffer Board (Plasma TVs only) - Standby light is on but no power
C) Backlight Inverter / LED Driver - No Video with standby light on
3. Main Video Board
- Either video or audio does not work (if no T-Con in TV. If audio but no video it is T-Con)
4. Power Board - No power AND standby light does NOT turn on. If standby light is on try other boards above
5. Panel - No power, distorted picture, lines, slow motion, half screen, faded in / out. Panel problems are usually not worth replacing the panel.
Televison & Video Logo
lg 42px-4dv/ea sustain pcb fails after 6 hrs running.
Try hard resetting;
NOTE:
Some TVs have a reset button. If available and accessible, try using the reset buttons before using the steps below. Using the reset buttons can save time.
Figure 1: Example of the reset button labeling on the LC2600N
1. Unplug the TV power cord from the power outlet.
2. Unplug any connected devices (DVD, Set-top boxes, etc...)
3. Press and hold the TV power button for five seconds.
4. Plug the TV power cord back into the power outlet and turn on the TV.
5. Open the on-screen menu to confirm that the TV is responding again.
6. Turn off the TV and reconnect the devices.
7. Turn on the TV.
Jul 21, 2008 | Televison & Video
I have a LG LED TV 55LS4500UD that no longer works after a storm. It won't turn on and no standby light. I have pics of the circuit boards. I would like to know which board to replace?
3. Main Video Board
Apr 11, 2016 | LG Televison & Video
I have a Vizio E422VA that will get to the Vizio logo screen, hold for about 1 minute then power off with the power light blinking for about 2 minutes. I have replaced the main board, power supply boa
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
Jan 22, 2015 | Vizio E422VA 42-inch Widescreen LCD TV -...
2,146 people viewed this tip
