Tip & How-To about Garden
Mower belt diagram 6
Toro-42-inch-deck
White-LT2200-46-inch
Yamaha-YT3600
Garden Logo
What fluid is used for the Hydrastatic transmission on a Yamaha YT3600
best advice is to contact the dealer and ask for the type of oil you are to use.
Apr 21, 2013 | Cars & Trucks
I have a Z4235 22hp Kawasaki with a 42 inch deck. The mower does not evenly. What can I do?
make sure you dont have a bent blade.if not check the mandrel housing and level the deck
Aug 15, 2011 | Toro 42 In Deck 19 Hp Kohler Courage Twin...
my 42 inch Toro seems to be cutting unevenly. The blades seem to be on correctly and I hope I haven't hit something to set the angle wrong
First thing to check is that the deck is level by the adjustments on wheels. Then check the bearings in the spindle housings and there is no play in the shaft when you try to move blade up and down. You then can measure from the blade tip bottom of deck on both sides (3 o'clock and 9 o'clock, and then 12 o'clock and 6'o clock They should all be the same. If not then either the shaft is bent, or the deck is bent slightly causing the blade not being parallel to the deck. If you have someone rotate the shaft you should be able to tell if the shaft is bent or not. If the deck is bent, then you will have to straighten it out till the spindle shaft is perpendicular to deck.
Oct 14, 2010 | Toro 42'' Zero Turn Lawn Mower 22hp Kawa...
toro 1991 42 inch mower doesnt cut even how do i
The blades should be a simple bolt on, how ever there are no adjustments at the blade. Your adjustments are on the swing brackets that raise and lower the deck.
Apr 26, 2010 | Toro Lawn Mower With Toro Power Tools
2,419 people viewed this tip
Top Garden Experts
Dennis Key
Dennis Key
john h
