Tip & How-To about Garden
Mower belt diagrams 4
MTD-46-model-13a0771h055
Murray-42-inch-deck
Murray-model-9-24536-deck
Murray-model-46577x71a-46-inch-deck
Garden Logo
Where do 4 springs go on 46 inch deck? The deck diagram I have does not make sense.
Hi Nick,
This may be the same diagram you already have, but this is the manufacturer engineering drawing for that deck.
MTD 13RN771H729 Yard Machines Lawn Tractor 2007 Home Depot Deck Assembly...
Aug 17, 2014 | Mtd Garden
Remove deck from 2007 yardman 46 inch cut
Contact MTD if your manual doesn't cover this, or buy a shop manual.
May 18, 2014 | Mtd LAWN MOWER PART # 983-04162A-0638 DECK...
need to know what size and hoe to change belt for yardman 46" cutting deck for blade model # 13a0771h055
If you are missing the manual, for the said model,
I have found that the simplest way, of figuring out the correct route for the belt, is to remove the deck, and hold the replacement belt above the mechanism, with the tension from the engine end.
Then 'mock up' the replacing proceedure, bearing in mind the correct direction the tensioner/s, move in.
Then it's not too difficult to figure it out the correct route.
Hope that's clear enough, good luck.
Jul 18, 2009 | Mtd 46" Dozer Blade, Fits All & Yard -...
Drive belt broken
That's a deck belt for a 42 or 46 in cut Murray deck. The size is 11/16 ths wide X 66 inches long. This is a wide belt .GOOD LUCK
Jun 22, 2009 | Garden
7,310 people viewed this tip
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
