Tip & How-To about Sewing Machines
Sewing Machine Needle Guide (Schmetz)
Want to know what sewing machine needle to use? Here's a handy guide.
http://www.schmetzneedles.com/learning/pdf/schmetz-needle-chart.pdf
Change your needles frequently. If you are experiencing problems with your stitch, the first thing to do is change out the needle. Needles get damaged and worn over time and are frequently the cause of stitching problems. Needles are the least expensive repair cost on your machine, so don't spare the expense!!!
Sewing Machines Logo
From where can i buy elna sewing machine needels? Pleace.
Consult your owner's manual for the size needles your machine takes. Usually, it is 130/705 needles.
If so, you can purchase this size from most any fabric, sewing repair shops, or online vendors. There are many manufacturers who make needles, ie Schmetz, Organ, Klasse, as well as Singer. Schmetz is readily available most places in the US. (IMHO, Singer needles are made more specifically for Singer sewing machines and may not work as well on a non-Singer machine. Most Singer machine manuals recommend using only Singer needles and some sewists have experienced problems when using a different brand.) You may have to experiment with brands if you have any problems with a specific manufacturer brand.
However, there is much more to choosing needles for your machine than the size and brand. The most important choices are to choose needles that suit the thread & fabric you will be sewing. Be sure to read up on the needle types (from smallest 65/9 to heavier 110/18) and the design/shape that will work best for you, ie sharps (for woven fabric) or ball-point (for knits), quilting, topstitch, embroidery, microtex, stretch, denim, universal, leather, etc.
"The European metric sizing system for sewing machine needles is numbered from 60 to 110. The American sizing system is numbered from 8 to 18. For both sizing systems, the lower the number the finer the needle and the higher the number the larger the needle. Most needle companies show both sizes on the package." (quote from Singer)
In addition, if your machine is capable, you may also be able to use twin, triple needles, wing, wedge point needles. The following will be helpful when you make your purchasing choices:
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=2&cad=rja&uact=8&ved=0ahUKEwjhzOqwyKzMAhVisoMKHUO2CR0QFggjMAE&url=http%3A%2F%2Fwww.schmetzneedles.com%2Flearning%2Fpdf%2Fschmetz-needle-chart.pdf&usg=AFQjCNHTR52AmqwzvyCjbXmD5Ch52Va5_Q
All About Needles
FREE Printable PDF Guide to Schmetz Sewing Machine Needles
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=3&ved=0ahUKEwjO4dSey6zMAhWpg4MKHUWjDAgQFgglMAI&url=http%3A%2F%2Fwww.joann.com%2Fon%2Fdemandware.static%2FSites-JoAnn-Site%2FSites-joann-project-catalog%2F-%2Fimages%2Fhi-res%2Fproject%2Fpdf%2FPA00223.pdf&usg=AFQjCNG8bnom5KfB1eLB6lEjHIsosUBgMw&cad=rja
Machine Needles
Apr 26, 2016 | Elna Sewing Machines
I have Hobbylock 774 what size of the niddles and brand I need to use
https://www.manualowl.com/p/Pfaff/hobbylock-774/Manual/184560
Jul 12, 2015 | Sewing Machines
what is the corrct replacement needle size
Choose the needle size according to the thread weight and fabric you will be sewing.
You can use this chart:
http://www.schmetzneedles.com/Schmetz_Sales_Guide.pdf
Feb 28, 2010 | Brother XL-5130 Mechanical Sewing Machine
1475 skips stitches when sewing batiks but works okay on everything else - what can I do I have changed the needle trying smaller and larger needles with some success but still haven't solved the problem.
I would wash a scrap of the Batik to see if this makes it more pliable.
The dying process seems to make this particular fabric a little dense.
You can just swish the scrap in a bowl of cool water with a couple drops of baby shampoo and then rinse well.
I think I would also try the micro-sharp needle.
This chart is a handy reference:
Feb 27, 2010 | PfaFF Sewing Machines
273 people viewed this tip
Top Sewing Machines Experts
Tally Girl
Tally Girl
Are you a Sewing Machine Expert? Answer questions, earn points and help others
