Tip & How-To about Miscellaneous
How to ask a question
When using a mobile phone to ask a question, remember that beside you looking at the faulty item, there is no one else looking over your shoulder
information such as make , model ,year will get an answer where as a statement will not get a reply
the message should be of full separated words ( no text) using correct names of parts or equipment and stick to the problem and do not ramble on..It is only confusing the issue.
Miscellaneous Logo
how do i retrieve items from the bin
Right click on the bin. A screen will pop up asking if you want to delete / empty the bin. ( Permanently destroy the rubbish) or if you want to restore a particular item.. If you click restore, the item will return to whatever file it was in when you deleted it. Look down the drop down box for the properties of the item you want to restore, it should say which file or what place the item came from. Remember this or write it down. Once you have restored the item, then you can look for it in its original file / folder. Cheers
Jan 05, 2015 | Cell Phones
mobile asking security code
Venkat, Thats a bad news, as whether you gave and forgot the password or someone didi it on purpose means nothing. Fact remains that the phone is asking for the code. Since you do not know it, the code will not allow you to acess the phone. Now the only way out is to get the firmware re installed from the service center of the phone make. Yes, you will lose all data. Hence lesson learnt is to keep backing up the phone data to the PC on a weekly or fortnightly basis besides not using a password.
Jun 01, 2010 | Nokia 5180 Cellular Phone
T-Mobile Dash half of the screen has white strips
i know its hard to belive but you may have cracked the screen by just bumping into something its a common problem with large screen phones i have tha same problem, you could buy a new ascreen on ebay have it installed or try to remember how to use it with out a screen, besides that if you dont have a protection plan on your phone youde have to buy a new one, and remember protections plans vary depending on the phone but are well worth it in case things do go wrong even if its not your fault
Aug 18, 2008 | T-Mobile Dash Smartphone
unlock phone
u could reset everything but everything besides whats on the sim card and memory card is gonna get deleted if u still wish to continue turn off the phone hold the two - - buttons under the screen and prower at the same time screen should be black and with writing asking if u wish to reset press yes and continue
Mar 16, 2008 | T-Mobile Wing™ Smartphone
154 people viewed this tip
Top Miscellaneous Experts
Andy Fraser
Andy Fraser
Dan Grod
Level 1 Expert
dennis lewis
Level 1 Expert
Are you a Miscellaneous Expert? Answer questions, earn points and help others
