Tip & How-To about Xantrex Technology Electronics - Others
Xantrex inverter error codes
This information expands upon the error code information contained in the Link 2000 Owner?s Manual.
E-01 Inverter high DC/Battery voltage shutdown Battery voltage has risen above 15.5 VDC for 12-volt models or 31 VDC for 24-volt models.
E-02 Inverter low DC/Battery voltage shutdown Battery voltage has dropped below 10 VDC for 12-volt units or 20 VDC for 24-volt units.
E-03 Inverter or Charger overtemp shutdown Unit will reset automatically after it has cooled sufficiently.
E-04 Battery overload Caused by excessively discharged batteries. See section in inverter owner?s manual titled ?Charging overdischarged batteries.?
E-05 AC Backfeed AC power from an outside source has been fed to the AC output of the inverter. Potentially damaging to the unit. Disconnect incoming AC power and correct the situation.
E-06 Electronic Overload Inverter overload caused by too large a load or a short circuit. Reset by cycling power switch or connecting incoming AC power.
E-07 Triac control error Triac has overheated. Shut down unit and allow to cool.
E-08 High battery voltage shutdown during charge mode Check all charging sources for proper voltage. Reset by cycling the power switch.
E-09 Spare
E-10 Link 2000 de-powered This indicates that power was removed and restored to the Link 2000.
E-11 Spare
E-12 Battery #1 voltage sense leads open Blue wire is not connected to battery #1.
E-13 Battery #2 voltage sense leads open Violet wire is not connected to battery #2. E-14 Inappropriate Charged V selected for sensed voltage This value defaults to 13.2 for a 12-volt system, 26.4 for a 24-volt system. If this setting is above the voltage limits of the charging source, this error code will be displayed. Please refer to page 9 of the Link 2000 Owner?s Manual
E-15 Incoming AC polarity reversed Check incoming AC wiring for a reverse polarity condition.
CCC Indicates battery being charged. Displayed when Time remaining is selected. LO BAT More than 50% of declared capacity of battery 1 or battery 3 has been consumed.
OL Meter reading out of range U xx Designates a user setup CEF. Please read the sections pertaining to CEF on pages 19?22. A Designates Alternator output current on a Link 2000-R. is a number from 1?200. P Indicates Percent of charge mode selected. is a number from 1?100.
Electronics - Others Logo
hi, i have a problem with my car, hyundai accent 2001 - the problems are P0722, P1529, P1805, P1801 - can you help me understand what they mean?
Trouble Code: P0722
A/T Pulse Generator 'B' Sensor Circuit Malfunction
Possible Causes:
Pulse generator 'B' (+) or (-) circuit is open or shorted to ground . Pulse generator 'B' is damaged or has failed. TCM has failed . TSB 01-40-006-1 (12/01) contains information about this code.
Trouble Code: P01529
Customer Snapshot Request Error
Possible Causes:
Transmission control module error. Check for trouble codes in the transmission control module. TSB 1-40-005 (3/01) contains information about this code. I have info. on these 2 codes,will search more for the others.
Aug 15, 2012 | 2000 Hyundai Accent
10.1000 memory error
Thank you for contacting FixYa with your printer inquiry.
This error is normally associated with a supplies error. I have extracted information on this error from the HP 6L manual.
Error Codes
Error 10 - Supplies Memory Error 10.XX.YY Exact format is dependent on printer model
    The printer is unable to read the electronic information (elabel) on the print cartridge. This helps track page count and life of consumable.
    XX Description 00 memory error on the cartridge or 01 memory device not found
    10.00.00 Black print cartridge
    10.00.01 Cyan print cartridge
    10.00.02 Magenta print cartridge
    10.00.03 Yellow print cartridge
  1. Supplies used in newer printer models contain a memory chip. The information contained on this chip is dependent on the printer model and the supply. The error 10 indicates a problem with the printer obtaining the information from this chip. The chip may be missing or defective or contain incorrect information. There may be a problem with connection between the memory chip and DC controller. Turn the printer off/on to attempt to clear or reset the message. Remove and reinstall the supply, replace the supply.
  2. Replace the memory chip cable/connector or the DC controller.
    How did we do?
Hope this helps helps. Please keep us updated and remember to rate this answer.
TF
Jun 08, 2011 | HP : HP6L Laserjet Printer
manual, for a aims 1500 pure sine inverter, not putting out. need manual or help in diagnosing the problem
The manual for aims1500 pure sine inverter is not available. The particular manual for this inverter is not not available.
Click the below link and check the inverter manual. You might find it helpful.
Click here: http://www.psui.com/pdf/75-1000-0001.pdf
Regards.
Jun 04, 2011 | Vacuums
Xantrex model rs2000. just purchased used. owner said all worked. got wired up, charger does not operate, shows no external power source, (led not lit). checked power to unit, at 119-123 acv.. inverter does work..
If it shows NO external source, then this is most likely the best place to look to find out why not?
http://www.ehow.com/how_7519715_troubleshooting-ac-inverter.html
Now above is a link that show you how to troubleshoot an AC inverter. Now below, there is a service manual, here at the back, is a factory troubleshooting chart that will be beneficial to you.
www.xantrex.biz/...Inverters/.../XS400_Owner_Guide(975-0054-01-01_Rev- B).pdf
The Biggest problems with Inverters is Flat/Low/Bad batteries, Sometimes it pays to remove the batteries and charge then up remotely, and then replace them, fully charged, Now a fully charged 12 volt battery should have 13.8 V DC at the terminals with NO LOAD. If the battery only reads 12 V it is not properly charged.
Dec 20, 2010 | Xantrex Technology Xantrex RS2000 Sine...
The Microwave is a Sharp Smart Carousel Model R-2130JS The food contains get hot but not the food
This model uses an inverter to product high voltage.
Due to the lethal voltages used and produced, I do not recommend that an inexperienced person work on these.
I would recommend that you contact your nearest Sharp-authorized servicer.
You can contact Sharp at 1-800-BE-SHARP (1-800-237-4277).
We're happy to help and we appreciate your thoughtful rating of our answer.
Apr 05, 2008 | Microwave Ovens
1,234 people viewed this tip
Top Xantrex Technology Electronics - Others Experts
Jimmer_9
Level 1 Expert
richie46
Jay Plesset
Are you a Xantrex Technology Electronics - Other Expert? Answer questions, earn points and help others
