Tip & How-To about Audio Players & Recorders
How to add LG Music Flow Speakers to Network
On PC
1. Open Music Flow, click on settings (cog wheel icon) at top right.
2. On left menu bar click on the plus sign in a double box next to speakers - this is the add component button, select the component you want to add.
3. The on the speaker you want to connect Press the Add Component button (on top of soundbar or back of speaker)
4. When the light on the speaker flashes red then click next on PC
5. Soundbar will flash the message 'connect'
6. You should get a success message
7. Either finish or add additional component for more speakers.
On iPad or Mobile App
1. Plug in speaker and LED will flash white
2. On App click Add Speaker and chose the type you have
3. On speaker press component button ( one with plus sign in a double box on top of Soundbar or back of speaker) and LED will start flashing red.
4. Press next on App and it will start searching then hopefully you will get a success message.
If you are using the bridge then if you are asked if it is wireless or wired you need to select wired as the Bridge is wired.
My computer does not recognize hardware. FYI: Machine hums when I insert a disk.
These are the steps to resolve the issue for the cd/dvd icon missing in the My computer.
Step 1: Please perform manual registry set up by following the below steps:
Please make a full backup of your registry files, particularly user.dat, system.dat, and policy.pol. If you make any incorrect entries, the backed-up registry files can be used to replace the corrupted registry entries.
Follow these steps to backup registry:
1. Click Start, select Run. In the "Open" field type REGEDIT
2. Click OK and click "File" in the menu bar
3. Click "Export" from the drop down menu this will open a new box
4. Click the down arrow beside "Save In" and select "Local Disk (C:)"
5. In the File Name field type BACKUP.REG Verify that under the "Export Range", that the radio button is beside "All"
6. Click Save.
Now make the following changes in registry:
1. Click Start and click Run(XP) or type Click Start and type regedit in search then hit enter(vista, Windows 7).
2. In the Open box, type regedit and click OK.
3. Click the plus (+) sign beside HKEY_LOCAL_MACHINE.
4. Click the plus (+) sign beside System.
5. Click the plus (+) sign beside Current Control Set.
6. Click the plus (+) sign beside Control.
7. Click the plus (+) sign beside Class.
8. Locate the {4d36e965-e325-11ce-bfc1-08002be10318} key and click it.
9. On the File menu, click Export.
10. In the File name box, type savedkey and click Save. It is better
to save the "savedkey" to the desktop.
11. Click the REG_MULTI_SZ data type UpperFilters (found in right
window pane) and then click Delete on the Edit menu.
12. When you are prompted to confirm the deletion, click Yes.
NOTE: If this data type is missing, continue to the next
method.
13. Click the REG_MULTI_SZ data type LowerFilters (found in right
window pane) and click Delete on the Edit menu.
14. When you are prompted to confirm the deletion, click Yes.
15. Quit the Registry Editor.
Step 2: Please uninstall the CD/DVD drive form Device Manager :
1. Click Start and select Control Panel.
2. Double-click the system icon. If the System icon is not found directly under Control Panel, click the Performance and Maintenance icon and then click the System icon.
3. The System properties Window opens. You can open the System Properties window directly by pressing the Windows key and Pause/Break key simultaneously.
4. Click the Hardware tab and then click the Device Manager button.
5. Click the plus (+) sign next to the DVD/CD-ROM drives .
6. Right-click the driver listed under this Category and select Uninstall. In the Confirm Device Removal dialog box, click OK.
7. Repeat step 6 until all entries under the device category are deleted.
8. Restart the computer.
After the notebook is restarted it automatically detects the drive and the drivers are installed.
Regards,
Shami
Nov 22, 2010 | HP DVD1040e DVD-RAM Burner
my computer will not recognize the dvd1260i burner
6. Click Save.
method.
Regards,
Shami
Oct 31, 2010 | HP DVD1260i DVDRAM Burner
I cant see my dvd/cd drive in"my computer" wndow, but it is visible in "device manager"
6. Click Save.
method.
Regards,
Shami
Oct 28, 2010 | HP (dc197x) CD-RW/DVD-ROM Combo Drive
TSST Corp CDRW/DVD TSL462D ATA Device (code 10) will not start up.
Please perform the below steps to fix the issue:
6. Click Save.
method.
Regards,
Shami
Oct 04, 2010 | Computers & Internet
Unable to locate my DVD/CD-ROM Drive in my computer
These are the steps to resolve the issue for the cd/dvd icon missing in the My computer.<br /> Download the fix patch form the below URL:<br /> <a href="http://support.microsoft.com/?scid=aw;en-us;314060&amp;eula=1">http://support.microsoft.com/?scid=aw;en-us;314060&amp;eula=1</a><br /> Please make sure you copy and paste the complete link in the address bar of a new Internet explorer window.<br /> If the issue still persists perform the steps in the sequence from here.<br /> Please uninstall the CD/DVD drive form Device Manager :<br /> 1. Click Start and select Control Panel. <br /> 2. Double-click the system icon. If the System icon is not found directly under Control Panel, click the Performance and Maintenance icon and then click the System icon.<br />3. The System properties Window opens. You can open the System Properties window directly by pressing the Windows key and Pause/Break key simultaneously. <br />4. Click the Hardware tab and then click the Device Manager button.<br />5. Click the plus (+) sign next to the DVD/CD-ROM drives .<br />6. Right-click the driver listed under this Category and select Uninstall. In the Confirm Device Removal dialog box, click OK.<br />7. Repeat step 6 until all entries under the device category are deleted.<br />8. Restart the computer. <br /> After the notebook is restarted it automatically detects the drive and the drivers are installed.<br /> If the issue still persists please download again the fix patch form the below URL:<br /> <a href="http://support.microsoft.com/?scid=aw;en-us;314060&amp;eula=1">http://support.microsoft.com/?scid=aw;en-us;314060&amp;eula=1</a><br /> Please make sure you copy and paste the complete link in the address bar of a new Internet explorer window.<br /> If the issue still persists please perform manual registry set up by following the below steps:<br /> <br />Please make a full backup of your registry files, particularly user.dat, system.dat, and policy.pol. If you make any incorrect entries, the backed-up registry files can be used to replace the corrupted registry entries. <br /> Follow these steps to backup registry:<br /> 1. Click Start, select Run. In the "Open" field type REGEDIT <br />2. Click OK and click "File" in the menu bar <br />3. Click "Export" from the drop down menu this will open a new box <br />4. Click the down arrow beside "Save In" and select "Local Disk (C:)" <br />5. In the File Name field type BACKUP.REG Verify that under the "Export Range", that the radio button is beside "All" <br />6. Click Save<br /> Now make the following changes in registry:<br /> 1. Click plus sign next to HKEY_LOCAL_MACHINE<br />2. Click plus sign next to System <br />3. Click plus sign next to CurrentControlSet<br />4. Click plus sign next to Control <br />5. Click plus sign next to Class <br />6. In the left hand window pane click {4D36E967-E325-11CE-BFC1-08002BE10318} to select that key <br />7. In the right hand window pane select the UpperFilters registry key and press the delete key on the keyboard Confirm with an OK <br />8. In the right hand window pane select the LowerFilters registry key and press the delete key on the keyboard Confirm with an OK <br />9. Click on the "X" in the upper right hand corner of the Registry Editor window to close it <br /> <br />You can refer the following web site for more information:<br /> <a href="http://support.microsoft.com/kb/314060/">http://support.microsoft.com/kb/314060/</a><br /> Please make sure you copy and paste the complete link in the address bar of a new Internet explorer window.<br /> <br />This should solve the problem with CD-ROM drive.
Aug 28, 2010 | HP Pavilion DV9910US Notebook
200 people viewed this tip
 Grubhead
Grubhead
