Tip & How-To about Horizon Exercise & Fitness
HORIZON FITNESS TREADMILL ENGINEERING MODE AND RUNNING BELT ADJUSTMENT
Eng0 - Display and Button Check
1. While in the Engineering Mode Menu, press Speed "+" or "-" until Eng0 appears in the display.
2. Press "Enter" to select Eng0.
3. Press "Start" button to verify all LED's
Eng1- Hardware Test
1. While in the Engineering Mode Menu, press Speed "+" or "-" until Eng1 appears in the display.
2. Press "Enter" to select Eng1.
3. Press "Start" button to verify belt movement, sensor wire, and elevation function.
Eng2 - Auto Calibration
1. While in the Engineering Mode Menu, press Speed "+" or "-" until Eng2 appears in the display.
For more check the following link . from the drop down menu select treadmills.
www.electro-medical.blogspot.com
Exercise & Fitness Logo
Horizon T91 Treadmill - Key Pad Troubleshooting
correct. If the console is not responding or some buttons do but others don't the membrane needs replacement.
Apr 02, 2017 | Horizon T92 - Treadmill
how to change the setting in the calculator so i can get an answer of 0.30233 for {0.35*0.8638} instead of the current answer 302.33m
You have turned the Engineering display mode ON. In that mode, the power of 10 that are displayed are multiples of 3. In your case the m stands for milli or (1 thousandth).
To exit the engineering ON mode, press the Mode button, several times (4) until you see EngON, EngOff. Press the corresponding digit key to turn off the Engineering display mode.
Mar 19, 2012 | Office Equipment & Supplies
hi i have a vision fitness 9450 hrt and i'm getting an error message: E6
Typically an E6 error message indicates that the machine needs to be recalibrated because the elevation motor is out of range or that you have a loose cable connection. Below are the auto calibration instructions. Please make sure that no one is on the machine because it will speed up quickly.
STEP 1 ENTER ENGINEERING MODE
With the safety key in place, hold "ELEVATION UP" and "SPEED
DOWN" buttons for 5 seconds. Software version will appear in display
window for a few seconds before model displays.
Press "STOP" , "ENG1" will appear in display window.
STEP 2 AUTO-CALIBRATE
Press "ELEVATION UP" until "ENG4" is displayed.
Press "SELECT" , display will read "AUTO".
Press "START". Unit will calibrate, when finished "END" appears in
display window, then "ENG1".
STEP 3 EXIT ENGINEERING
Press and hold "STOP" to exit engineering mode
I would also suggest that, with the power to the machine off, you check all of the wire connections underneath the motor cover, the assembly connection that sits where the mast meets the console and underneath the faceplate. Check to be sure that all of the connections are secure and that the pins within the cables are seated properly.
If you are still having any problems you can reach a knowledgeable Vision Fitness Representative toll free at 800-335-4348.
Mar 29, 2011 | Dmm Vision Fitness T9500 Treadmill
Why won't my vision fitness simple T9500 run? I tried holding down the stop button for 3 seconds. It did clear the screen. Then when I hit start it puts 6000 in the screen and will not run. It beeps as if it recognizes my request but will not run. I tried to reset but the 6000 stays in the display.
With the safety key in place, press and hold “ELEVATION UP” and “SPEED DOWN” for 5 seconds. The software version will appear in display window shortly before model number appears. Press “ENTER” to accept correct model number IF YOU CANNOT GET INTO CALIBRATION EITHER UPPER CONSOLE ELECTRONICS OR OVERLAY CONSOLE ASSEMBLY HAS FAILED.
• Press “STOP” to enter “ENG1”. Press “ENTER”. PLEASE NOTE: HR Window = “0” for miles, “1” for kilometers, treadmill will calibrate in kilometers if set for kilometers. STEP 2 MINIMUM SPEED • Press “ELEVATION DOWN” button, “P0” will appear in display. • Press “START” button, the running belt will begin to move at minimum speed. • The display window should read approximately “.49 - .51”. • To adjust, press “SPEED UP” or “SPEED DOWN” buttons, the range should be “.49 - .51”. Press and hold “ENTER” to save changes. Press “STOP” to return to “P0”. STEP 3 1/4 SPEED • Press “ELEVATION UP” button, “SP1” will appear in display. • Press “START” button, the belt will move 1/4 speed. • The display should read approximately “2.71 - 2.73”. • To adjust, press “SPEED UP” or “SPEED DOWN” buttons, the range should be “2.71 - 2.73”. Press and hold “ENTER” to save changes. Press “STOP” to return to “SP1”. STEP 4 1/2 SPEED • Press “ELEVATION UP” button, “P1” will appear in display. • Press “START” button, the belt will move at 1/2 speed. • The display should read approximately “6.72 - 6.73”. • To adjust, press “SPEED UP” or “SPEED DOWN” buttons, the range should be “6.72 - 6.73”. Press and hold “ENTER” to save changes. Press “STOP” to return to “P1”. STEP 5 3/4 SPEED • Press “ELEVATION UP” button, “SP2” will appear in display. • Press “START” button, the belt will move at 3/4 speed. • The display should read approximately “9.41 - 9.43”. • To adjust, press “SPEED UP” or “SPEED DOWN” buttons, the range should be “9.41 - 9.43”. Press and hold “ENTER” to save changes. Press “STOP” to return to “SP2”.
STEP 6 MAXIMUM SPEED • Press “ELEVATION UP” button, “P2” will appear in display. • Press “START” button, the belt will move at maximum speed. • The display should read approximately “12.10 - 12.12”. • To adjust, press “SPEED UP” or “SPEED DOWN” buttons, the range should be “12.10 - 12.12”. Press and hold “ENTER” to save changes. Press “STOP” to return to “P2”. STEP 7 MINIMUM ELEVATION • Press “ELEVATION UP” button twice, “P4” will appear in display. • The display should ready approximately “190 - 205”. • To adjust, press “ENTER” for value which should read “190 - 205”. Use “SPEED UP” or “SPEED DOWN” buttons. Press and hold “ENTER” to save changes. Press “STOP” to return to “P4”. STEP 8 MAXIMUM ELEVATION • Press “ELEVATION UP” button, “P5” will appear in display. • The display should read approximately “750 - 765”. • To adjust, press “ENTER” for value which should read “750 - 765”. Use “SPEED UP” or “SPEED DOWN” buttons. Press and hold “ENTER” to save changes. Press “STOP” to return to “P5”. REMOVE SAFETY KEY TO EXIT ENGINEERING MODE REPLACE SAFETY KEY AND PRESS START TO TEST TREADMILL
Jun 14, 2010 | Dmm Vision Fitness T9500 Treadmill
1,104 people viewed this tip
Top Horizon Exercise & Fitness Experts
Electro Med Services...
Matt Olenzek
Matt Olenzek
Jerry Kramer
Jerry Kramer
Are you a Horizon Exercise and Fitnes Expert? Answer questions, earn points and help others
