Tip & How-To about Chevrolet bolt. generator mounting. intake & exhaust manifold
Penatrating oils
A popular magazine actually tested penetrants for break out torque on rusted nuts.
Significant results! They are below, as forwarded by an ex-student and professional machinist,
They arranged a subjective test of all the popular penetrants with the control being the torque required to remove the nut from a "scientifically rusted" environment.
*Penetrating oil ..... Average load*
None ..................... 516 pounds
WD-40 .................. 238 pounds
PB Blaster ............. 214 pounds
Liquid Wrench ..... 127 pounds
Kano Kroil ............ 106 pounds
ATF-Acetone mix....53 pounds
The ATF-Acetone mix was a "home brew" mix of 50 - 50 automatic transmission fluid and acetone.
Note the "home brew" was better than any commercial product in this one particular test. Our local machinist group mixed up a batch and we all now use it with equally good results. Note also that
"Liquid Wrench" is about as good as "Kroil" for about 20% of the price. "
Chevrolet bolt. generator mounting. intake & exhaust manifold Logo
how to remove stripped bolt
Hi Anonymous, it all depends on the size and location. That being said I would take your bike to your local dealer or reputable shop and they will be happy to remove it for a small fee. Good luck
Mar 29, 2014 | 2004 Harley Davidson XL 1200 R Sporster...
Removing rusted nuts from bolts to replace toilet seat
Try:
* Penetrating oil...let it soak at least 1/2 hour
* If the nut is stripped, try either grabbing it with vice grips
* If all else fails, either grind it off, or use a nut splitter. Nylon is pretty soft, so it should be relatively easy to break
Apr 26, 2009 | Bemis 7MCLRDRCT NA Elongated Toilet Seat...
Front Right stud replacement
Usually the torque spec for those nuts is pretty high, and they suffer from what I call "environmental torque" as well (exposure to the elements and to heat cycling that can cause it to seize). Your best bet first off to try, is to spray it down with PB Blaster several times, with maybe 15 minutes between sprays. This will keep it doused and allow it to penetrate. If you have some, or can get some, a penetrating oil like Deep Creep can work even better, as it can get down into gaps a millionth of an inch in size.
If that doesn't work, many tool rental places can rent you an electric impact gun for maybe $20/day or so. Something like that, which can give you an instantaneous blast of strong torque, can often break a stuck nut free. You can also put a flat-blade screwdriver against each flat side of the nut, one at a time, and whack the screwdriver handle with a hammer - sometimes this can break the seizing free.
At this point, you're down to chemical penetrants and brute force. I've found that one or more of these methods usually works for me.
Oct 20, 2008 | 1990 Nissan Stanza
319 people viewed this tip
Top Chevrolet Electrical Supplies Experts
Lawrence Oravetz
jdthefixer
Mike Carew
Are you a Chevrolet Electrical Supply Expert? Answer questions, earn points and help others
