Tip & How-To about Magnavox Televison & Video
Service menu codes phillips magnavox
I provide this information for those that are qualified and trained to do TV repair work. Entering or making changes in service mode by untrained persons can cause significant and permanent damage to your television. If you are not qualified to service your television, please DO NOT ENTER these service menu codes
# Press {0} {6} {2} {5} {9} {7} {INFO+} on the remote.
or
# Press {0} {6} {2} {5} {9} {7} {STATUS} on the remote.
or
# Press {0} {6} {2} {5} {9} {7} {MENU} on the remote.
# Turn the TV off to exit the Service Menu
* Press {0} {6} {2} {5} {9} {6} {INFO+} on the remote.
or
* Press {0} {6} {2} {5} {9} {6} {STATUS} on the remote.
or
* Press {0} {6} {2} {5} {9} {6} {MENU} on the remote.
* Turn the TV off to exit the Service Menu.
* Press {0} {6} {1} {5} {9} {6} {MENU} on the remote.
or
* Press {0} {6} {1} {5} {9} {7} {MENU} on the remote.
* Turn the TV Off to exit the Service Menu.
* Press {1} {6} {2} {5} {9} {6} {MENU} on the remote.
or
* Press {1} {6} {2} {5} {9} {6} {STATUS} on the remote.
* With the TV off:
Models 15MF605T/17, 20MF605T/17, 15MF500T/37:
To Factory Mode:
Step 1 : Select the source "PC" and then turn off LCD-TV.
Step 2 : [Push "power " button and then push the "VOL- " and "VOL+" buttons at the same time immediately and hold it] about five seconds then release all buttons.
Press "menu"button and bring up factory mode indication
Televison & Video Logo
I need a service menu code for a rca sld58g45rq tv.
this information for those that are qualified and trained to do TV repair work. Entering or making changes in service mode by untrained persons can cause significant and permanent damage to your television. If you are not qualified to service your television, please DO NOT ENTER these service menu codes.
* Turn the TV off.* Press simultaneously the {MENU} {VOL -} {CH -} buttons for about 8-10 seconds.
* The TV will turn on with the Service Menu displayed.
* Press the {POWER} button to exit. thank you..
Nov 04, 2017 | RCA Televison & Video
I HAVE CHANGE MY TV EPROM I NEED TV CODE TO SETUP
NOTICE: MUST READ BEFORE USING SERVICE CODES!!! RiddledTV.com provides this information for those that are qualified and trained to do TV repair work. Entering or making changes in service mode by untrained persons can cause significant and permanent damage to your television. If you are not qualified to service your television, please DO NOT ENTER these service menu codes. * Unplug the power cable. * Press and hold the {MUTE} button on the remote control while plugging the power cable back into the outlet. * Keep pressing the {MUTE} button until the TV powers on with the Service Menu displayed. * Use the {CH+} {CH-} buttons to select menus. * Use the {VOL+} {VOL -} buttons to change settings. * Some menus might have sub-addresses. Use the numeric buttons {0} to {7} to adjust sub-item data. * Press the {MENU} button or turn the TV off to exit.
Aug 06, 2012 | Televison & Video
1,525 people viewed this tip
Top Magnavox Televison & Video Experts
Demonic-2011
Demonic-2011
Tom Chichester
Are you a Magnavox Televison and Video Expert? Answer questions, earn points and help others
