Tip & How-To about Hardware & Accessories
Timers and other swithes
Do not under any circumstances to mix and match parts. you will only get yourself into a bigger and more expensive mess to fix.
my advice if ur gonna do it yourself do it right and follow instructions.
Hardware & Accessories Logo
I have a analog percision power supply. I put all new parts in it new fuse holder plug switch. I dont know how to connect them. Can u show me in lamens terms.
You really shouldn't mess about with power supplies if you don't know how to do them. It would be wrong for a Fixya member to explain it to you as even with the best advice going, you could electrocute yourself, or start a fire. We can't even be certain you have bought the correct safety parts. I suggest you take the device to a trained person - with the parts - and let them fix it for you. Before you do yourself an injury or kill yourself.
Apr 25, 2015 | Audio Players & Recorders
Color will not match up
if your talking about the sets convergence does not line up and it looks like a 3-D picture than The best advice I can tell you at this point is to go to tvrepairkits.com and order the complete convergence kit for your model of TV set, no need to search and order multiple parts from different sources and pay multiple shipping fees! Go to http://www.tvrepairkits.com/xcart/home.php?partner=larry
The kit comes with original Sanyo STK IC'S , not those cheap aftermarket or china made IC'S full pictorial directions, the thermal paste, resistors, the correct Pico fuses, AND free live on-Line tech assistance in case you run into a problem with the repair. They ship out 2 to 3 day Priority mail, the next day in most cases GOOD LUCK!!!
Larry Dillon.
http://www.fixya.com/support/r3342653-convergence_fix
May 08, 2010 | Hitachi 51UWX20B 51" Rear Projection...
my dodge truck at times won't accelerate over 1500 rpms without stalling out, can anyone give me any advice
depending on your dodge year it could be your catalitic converter .it could be that wonderful oxy sensor . if its a standard it could be aclutch cable check your timing is coreoct the timing spec will be on the tag under the hood as most have seperate settings.i will asume you have replaced youre fuel filter as earlier dodges went through them . oxy sensors should be replaced every 100,000 kms.start with your fuel filter. do not mess with your idle you will have big problems like the set screw is tuff to turn ,you could screw this part by forcing it then there is no fixing this part and it is expensive how ever if it is loose or sloppy then it needs replaced anyway because its buggering your truck you can do this yourself but there is anologic procedures to it.based on youre info thats all ihave
Nov 09, 2009 | 1990 Dodge W150
gas tanks rupture on craftsman lawn tractors
2 of them, one is take it to craftsmen and see if they will fix it as a manufacturing defect, or you can replace the tank yourself. There is a putty that you can use, just go to the auto parts store and tell them what you need. Some of them can't be used on gas components so be careful or you will be right back in this mess, only with a bigger mess on your hands.
Calvin.
Apr 24, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
386 people viewed this tip
Top Hardware & Accessories Experts
Gene Haynes
Hippy_dd
Are you a Hardware and Accessory Expert? Answer questions, earn points and help others
