Tip & How-To about Check Point Computers & Internet
Establish a Security Baseline for Windows (XP Service Pack 3 and all other versions since released)
Run Silent, Run Deep
Overhead reduction is the least commonly used concept of behavioral practice in those minds where it is most needed. In terms of your PC's software firewall, I strongly recommend disabling the default Windows Firewall in favor of ZoneAlarm. The former is prohibitively greedy with resources both logical and physical, and the latter has been stone-faced serious from Day One about intelligent, adaptive, two-way firewalls. The Contender has returned in both PRO and FREE versions.
Firewall => Checkpoint; ZoneAlarm Firewall (paid & free):
ZoneAlarm PRO Firewall Software Internet Firewall Protection
ZoneAlarm Free Firewall 2015
Computers & Internet Logo
My Howard Miller battery operated mantel clock model 612-588, movement 354078F doesn't chime. My wife thinks she might have changed a setting or switch accidentally. How do I re-set it?
There is a switch from 'chimes off' and two variants. There is also a night clime cut off or volume reduction.
. CHIME MELODY
Use the switch with the symbols
OFF, WEST, and MELODY2
to select the chime melody according to the following settings:
O
FF = Silent
WEST = Westminster melody and full hour strike
MELODY2 = Ave Maria melody and full hour strike (Beethoven's Ode to Joy on select models)
. VOLUME CONTROL
The volume of the chime can be modified by turning the Volume Control knob.
5. AUTOMATIC NIGHTTIME CHIME SHUT-OFF
The movement has automatic nighttime volume shut-off or volume reduction options for a period of eight (8) hours after the switch is moved to the shut-off or volume reductions positions. This feature will automatically repeat at the same time every 24 hours. Use the switch with the symbols to select chime silencing according to the following settings:
Chime silent for eight (8) hours
Reduced volume for eight (8) hours
Full chime volume
Here is the manual
http://bigbenclocks.com/img/products/manual/quartzmanual.pdf
Nov 07, 2017 | SHE Home
When i am taking picture in bulb,camera is taking to long,sometimes 3-4min, to show picture on LCD after shooting.It's brand new camera canon 550d. My canon 500d, what i used to have before, never had this problem.Thank you
This is normal behavior for taking a picture using the bulb. After you release the bulb, the camera may detect that a noise reduction step is necessary. The noise reduction process can take as long as the exposure time. There is an option to disable long exposure noise reduction. Click here to see the manual for details.
Apr 14, 2011 | Canon EOS 550D Rebel T2i Digital Camera
Garmin 255w voice goes silent while giving directions.
I recommend you backup your favorites.
Then I suggest a hard reset. This will clear up some erratic behavior.
Finally, replace the firmware and system software using webupdate.
Replacing the firmware should allow it to run reliably like new
I hope that helps.
Mar 13, 2010 | Garmin nuvi 205W GPS Receiver
crease reduction facility won't work
Crease reduction facility is just a slower spin cycle if you coose a delicate wash there will be no apparent difference
Mar 07, 2009 | Washing Machines
368 people viewed this tip
Top Check Point Computers & Internet Experts
steve morris
steve morris
ray gallant
Are you a Check Point Computer and Internet Expert? Answer questions, earn points and help others
