Tip & How-To about Michelin Stealth Ultra Hybrid Wiper Blade, 26" - 8526
How to remove a Michelin Stealth Hybrid Wiper Blade
There are two flexible retaining tabs at the TOP of the wiper blade mounting, not at the bottom where the release typically is.
Line up the holes in the metal frame so that they are behind the tabs then press on the tabs with a small screwdriver one at a time while pushing down on the wiper blade, releasing one side then the other. The blade will side right off.
Don't push too hard or you can bend the wiper arm.
Michelin Stealth Ultra Hybrid Wiper Blade, 26" - 8526 Logo
the rear window wiper blade holder is rusted how do I remove it for replacement?
Three things you can replace depend on your budet
1) you can replace whole wiper blabe assembly by lift up the cover at the bottom end of the bale assembly and un-screw the nut and raplace whole assembly with arm , wiper insert etc ... with the new one This way cost you more.
2) on hte middle of the whole wiper blade assy has the flexible section, you can un-screw 2 small philipe pan head screw with screw driver and disconnect the top section with the wiper blade insert (rubber)
3) slide wiper blade insert out of the holder, becareful with 2 small steel blade will hole your rubber insert inside the wiper frame. Slide new rubber insert in the frame .
Feb 25, 2011 | 1995 Toyota Supra
where is windshield wiper motor for 1992 mercury grand marquis
1992-98 Vehicles
  1. Disconnect the negative battery cable.
  2. Remove the rear hood seal. Remove the wiper arm assemblies by raising the wiper blade off the windshield. Move the slide latch away from the pivot shaft and slowly lower the arm onto the latch. This unlocks the arm from the pivot shaft and holds the blade off the glass. Pull the arm from the pivot shaft.
  3. Remove the cowl vent screws and disconnect the washer hoses from the washer jets.
  4. Detach the electrical connectors from the wiper motor.
  5. Remove the wiper assembly attaching screws, lift the assembly out and disconnect the washer hose.
  6. Unsnap and remove the linkage cover.
  7. Remove the wiper module assembly retaining bolts and remove the module from the vehicle.
  8. Remove the linkage retaining clip from the motor operating arm by lifting the locking tab and pulling the clip away from the pin.
  9. Remove the motor retaining screws and remove the motor from the vehicle.
  10. The installation is the reverse of the removal.
Fig.: Lift up to release the clips and remove the hood-to-cowl weather strip
Fig.: Remove the cowl panel-to-firewall retaining clips
Remove the driver's side then the passenger side cowl panel from the vehicle
Fig.: Detach the electrical connector for the wiper motor
Release the wiper motor retaining clips and remove the cover from the vehicle
Fig.: Remove the wiper module assembly retaining bolts and remove the module from the vehicle
Fig.: Remove the wiper motor retaining bolts and ...
Fig.: ...remove the wiper motor from the vehicle
Hope helps (remember comment and rated this).
Aug 02, 2010 | 1992 Mercury Grand Marquis
I have a 92 chevy S10 truck, how do you remove the wiper blades and arms?
GM S10/S15/Sonoma Pick-Ups 1982-1993 Repair Manual Blade and Arm - REMOVAL & INSTALLATION
(see Figures 1, 2 and 3)
  1. Matchmark the base of the wiper arm to the linkage. This will assure the arm is installed in the proper position. If the arm is being replaced, transfer the matchmark from the old component to the new one before installation. This can be done by placing the new arm on top of the old one and copying the mark.
Fig. 1: Removing the wiper arm using J-8966
Fig. 2: If no wiper arm tool is available, use a small prytool to depress the spring
Fig. 3: With the spring released, pull the wiper arm from the linkage
  1. Most wiper arms are retained by a spring clip. Some are equipped with a release tab at the center which should be depressed to release the arm. If no tab is provided, use a small prybar or a wiper arm removal tool such as J-8966 to depress the spring and release the arm. Remove the arm from the vehicle.
  2. Some late model vehicles (all 1993 and some earlier models) are equipped with a wiper arm that utilizes a small release hole at the base of the wiper arm. If equipped, insert a 1 / 8 in. drift pin into the tool access hole to release the locking device and allow the arm to be easily pulled from the transmission. If necessary, use a gentle rocking motion to remove the arm.
To install:
  1. Except for late model vehicles equipped with the tool access hole, align the matchmarks and gently press the blade over the linkage and snap into position.
  2. For 1993 vehicles (and earlier models equipped with the access hole on the arm) straighten the arm assembly and insert the pin. Align the arm with the linkage mark made earlier, then press down on the arm's head casting until it seats and locks onto the wiper pin. Remove the drift pin.
  3. Operate the wipers and verify proper alignment.
Hope helps (remember rated this).
Jul 08, 2010 | 1992 Chevrolet S-10
how do I replace the grill on my 1990 Pontiac Grand Am
1989-91 GRAND AM
Fig.: When installing the grille, snap the retainer tabs into the slots in the mounting panel, inserting the bottom tabs first
To remove grille, just release the tabs and pull grille the outward. Installation is done by inserting grille and locking the retaining tabs.
  1. Unfasten the screws along the top of the grille.
  2. For Achievas, unfasten the retainers from the bottom of the grille.
  3. Pull out on the grille to release the lower tabs.
  4. Installation is the reverse of the removal procedure.
Hope helped (remember rated this help) Good luck.
Nov 02, 2009 | 1990 Pontiac Grand Am
I cant figure out how to change my windshield wiper blades on 2001 ford ranger
How to Replace Wiper Blades Guide (Typical):
Potential tools needed to replace wiper blades:
  • Flat blade screwdriver (small)
  • Small nosed pliers
  • Latex or vinyl gloves
  • Safety goggles
To replace wiper blades theactual action of replacing the blade is no big deal, it's the locationof the blade down below the hood that can make it difficult though.Sometimes it helps to open the hood to gain access to the wiper blades.Other times it is helpful if the wiper blade is somewhere in the motionline of wiper action. The trick is to get the wiper to stop somewherein the wiper arc. Turn the wipers to the on position and allow thewipers to start, and then shut the key off when the wiper has arrivedin a desirable position on the windshield. To replace your wiper bladesplease follow the step by step instruction below. Also, watch the How to replace wiper blades video below to gain additional information. The method in which the wiper blades are attached will vary slightly.
  • Step 1: With the hood closed, turn the wiperson, when the wipers are in the middle of their arc turn the key to theoff position. (Note: if this can't be done because of wiper conditionand you want to avoid scratching the windshield please open your hoodto gain access)
  • Step 2: Locate the mounting clips at the top pivot on the wiper blade
  • Step 3: Release the clip and remove the wiper arm
  • Step 4: Match the size of the old blade against the new blade to ensure proper fit and operation
  • Step 5: Reinstall the new wiper blade and recheck wiper operation
Common Problems:
  • Make sure the wiper blades are the same size as the original blades.
  • When replacing wiper blades not getting the blade onthe mounting pin completely allowing the wiper arm to become dislodgedand possibly causing damage to the windshield.
  • Using wiper blades after the blade has failed permanently damaging the windshield by craving scratches in the wiper arc.
  • Wiper blade can create a chattering noise when theblade is not properly balanced allowing the blade to "flop" back andforth as the wiper direction changes.
I hope help you with this (remember rated this help) Good luck.
Sep 16, 2009 | 2001 Ford Ranger Regular Cab
1,609 people viewed this tip
Top Michelin Photography Experts
pontelemon
pontelemon
Tony
Are you a Michelin Photography Expert? Answer questions, earn points and help others
