Tip & How-To about Home
Dusting eletronics and appliances
Ignoring dust build up is one of the greatest contributors to over heating and eventual breakdown of electronics and appliances. Keep your items lasting longer by following these few hints.
Electronics: Computers, Keyboards, TV's, VCR - DVD- CD players, Radios,
Air Purifiers.....Can be easily dusted with air-cans, little micro-
dusters, vacuums, and believe it or not even with used dryer sheets.
Always have units turned off and unplugged before dusting.
If you are comfortable with removing casings you will be able to remove more dust.
DO NOT use wet cleaners, soaps, water, as it will short out your electronics. Exception is the use of Is-propyl Alcohol which you can dip q-tips into and clean in the little tight spots if necessary as it evaporates quickly.
Especially useful on heads in players.
Appliances: Dryers, Refrigerator, Freezers, Ranges,
all require "space and breathing room."
Dryers are one of the leading factors in house-fires because of the build up of lint. At least once a year (more with a big family) unplug dryer and do a deep clean.
You want to focus getting lint out from behind, inside the dryer, and duct.
Refrigerators and freezers you want to pull away from wall & get the dust vacuumed
off the coils. Though not popular practice with many, it is wise to try and not store
a bunch of clutter on top of these appliances. Make sure to mop the floor before
pushing back into it's space.
Ranges though not as sensitive to dust still should be deep cleaned for food particles and grease buildup. Pull the drawer out from bottom and clean out the space of crumbs. Grease buildup on range hood lights can cause early blowouts.
Make sure bulb is cool to the touch before attempting to clean to avoid breakage and finger burns.
This is not meant to be an exhaustive walk through, but only to serve as a spring cleaning reminder that awareness and a little cleaning can save on repair bills and replacements.
How To Clean Electronic Devices
Dryer Lint Cleaning Tips
Home Logo
My hd1080 color is multi and my picture is blurred
Unless the unit was moved and RGB section misaligned, the other condition could be a defective controller circuit board.
If it is old, heat builds up over time and the components start to breakdown. Remove the back of the TV and see if there is a collection of dust and debris that could effect the operation of the TV.
May 10, 2014 | Mitsubishi WS-65413 65" Rear Projection...
smsc intel too hot and my computer is not display anything
Have you tried cleaning out all of the dust possibly from build up?, if so, how about the fans? 99% of all heat problems are due to lack of maintenance. Now if you did clean all items of dust build up and there is still the problem of no display, you may need to instal a video card. The onboard video may no longer be working and therefor the possiblility of a new video card.
Oct 31, 2013 | Dell OptiPlex Computers & Internet
My FSP300-60EP1 has like burn markings on bottom of it. And my CPU had dust build up on it completely. What do I do?
Overheating When the CPU overheats then it will shut down (i.e. thermal overload) and won't boot up again until it has cooled down. If this is the problem is not fixed then the CPU will eventually fail.
A faulty fan causes the problem or the fan and heat sink assembly are clogged with dust.
Check the CPU fan to see if it spins freely, if not replace the fan.
If the fan and heat sink is clogged with dust the remove the dust and make sure the vents are clear and dust free. Use a small brush and can of compressed air to do this.
Jan 16, 2013 | Computers & Internet
Freezer not freezing frig not as cold as it should be freezer has frost build up behind inside shelving ice maker not working temp settings set cold. GE Profile Arctica mod#PSS23LGSA WW
Check your recirculation fan first . It is located in the freezer compartment . Make sure it is working properly . It should run continuously except when it is in the defrost mode . If OK , you're problem is probably in the defrost circuit itself . If the unit does not defrost properly every six or eight hours , depending on the timer control , ice will build up on the evaporator preventing airflow over and through it during normal operation . Also , check your door seals condition and sealing when the doors are closed .
Sep 16, 2010 | Refrigerators
IN MY JUST PURCHASED UNIT I HAVE ENCOUNTERED WHAT APPEARS TO BE DUST OR PARTICLE SPECKS IN THE VIEWING SURFACE WHICH ARE MOT RELATED TO THE NEGATIVES OR SKIDES. I HAVE SCANNED APPROXIMATELU 900 SLIDES AND TGE PROBLEM HAS OCCURED WHEM I STARTED TO SCAN SOME NEGATICES. I DUST AND CLEAN ALL ITEMS PRIOR TO SCANNING. IS THERE A WAY TO CLEAN THE UNIT? THNAKS, BILL HANSON BRANDON FLORIDA
Most of these devices have photoelectric sensors build-in, which tells the unit whether there is too much paper dust on the sensors, When there is too much paper dust covering the sensor, the device will report to the User that there is too much paper dust on the sensor, and the device will not function properly, due to the build up of paper dust.
Get a can of compressed air and gently spray inside the device, to remove the build up of paper dust,
-a.
Dec 06, 2009 | Pacific Image Electronics Memor-ease...
945 people viewed this tip
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
