Tip & How-To about Otc Tools OTC STUD REMOVER - 8 MM - OTC6987-8
Extracting bolts Mechanical Database
Otc Tools OTC STUD REMOVER - 8 MM - OTC6987-8 Logo
im missing the center bolt that holds my crankset together. i have Truvativ racing jr cranks
Judging by the picture here...
http://www.amazon.com/Truvativ-Racing-Crankset-175mm-Mirror/dp/B000NNSZ6U
It's just a garden-variety self-extracting crank bolt. They come in many colors if that matters. A standard bolt would work, too.
Find one using your favorite Search Engine.
example:
http://gallery.roadbikereview.com/showphoto.php/photo/113763/si/self
Your local Bike Shop will have them.
Jun 03, 2011 | Dmm Truvativ Racing Team Bmx Crankset,...
does the starter for the 1989 clubwagon have two mounting bolts? It looks like the head of one (the top one) may be broken off leaving me unable to take out the broken starter.
Hi!!
It does have only two mounting bolts.
because of the thight space to work in the upper bolt, nd since starter is not working, what I would do is take the bottom bolt off and wiggle the starter until it breaks free, then work on extracting broken bolt.
Good Luck
If helpful, click below
Feb 01, 2010 | 1989 Ford Econoline
2001 mercedes Ml430 torque specifications front & rear brake caliper bracket bolts & caliper bolts?
Your public library will have a manual covering your mechanical repair. Moreover, they have the automotive shops online software called AllData. It is the best auto technician database available today. You can print out specific troubleshooting procedures, diagrams, step-by-step istructions, and soforth. The typical person cannot afford to pay for this service, just automotive dealerships, etc... that is why the public library made it available to everyone and for free to view and print out material. This should Fixya! Good Luck!
Aug 27, 2009 | 2001 Mercedes-Benz C-Class
How do I get the rear housing off the np231 t-case bolt are out but the unit wont come out
Aug 19, 2009 | 1988 Jeep Cherokee
check engine light with a p 303 code
Initially what is needed is to determine the "code of failure", then know that it and afterwards make l intervention...
Extracting Fault Codes
(sample for an 1991 year; the procedure is the same for other years).
On Board Diagnotic Code Database
(select your type ODB by year's car)
Good luck!!!
Jul 28, 2008 | 1993 Jeep Grand Cherokee
268 people viewed this tip
Top Otc Tools Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
Are you an Otc Tools Heating and Cooling Expert? Answer questions, earn points and help others
