Tip & How-To about Dryers
Samsung dryer error codes
Samsung Dryer Fault Codes
ts Thermistor shortCheck for restricted vent. Replace thermistortoThermistor openCheck for restricted vent Replace Thermistor
do Door OpenCheck connections. Replace door switch.
FE Power Source Frequency errorCheck power source
dF Door circuit failureCheck wiring to door switch. Replace door switch
hE Heater errorRestricted vent. Replace thermistor.
bE Button ErrorCheck and / or replace PCB
od Over drySensor Bar open. Adjust time up excessively.
Et eeprom failureReplace Eeprom
Dryers Logo
samsung vtr error code t5 what is it
"Ts" error code usually indicates restricted air flow in the vent (could be internal or out of the dryer. In some cases could be the thermistor itself that gives out false reading.
Feb 11, 2015 | Samsung Dryers
WHAT DOES ts error code on a samsung dryer
A ts error means that there is either a thermistor short or the vent is blocked. First check the entire dryer vent from the dryer to the outlet. Clean any lint build up and make sure that the vent isn't constricted around any objects if you have flexible ducting. Check that the flap hasn't shifted to block the vent outlet. (I've seen this a few times.)
If that doesn't solve the problem, replace the thermistor. It's part 7 on this diagram: http://www.searspartsdirect.com/partsdirect/part-model/Samsung-Parts/Dryer-Parts/Model-DV209AEWXAA0000/1482/0151200/50039356/00005?blt=06&prst=&shdMod= . If your dryer is still under warranty, contact Samsung for the repair.
I hope this helps.
Sep 05, 2014 | Samsung Dryers
dryer runs for 10 seconds amd then stops. code t5 comes up
That is actually a Ts error.
Thermistor Short Sensor
The Thermistor resistance is very low.
Check for:
- Clogged lint screen.
- Restricted vent system.
- Check Thermistor resistance.
Thermistor is Item #27 HERE
Oct 08, 2011 | Dryers
I am getting a T0 code on my dryer. I have cleaned all the vents
Thermistor open
If you need further assistance please feel free to comment
Jul 27, 2011 | Samsung DV218AEW Electric Dryer
my dryer shows hE code what does it mean its a samsung
Samsung Dryer Fault Codes ts Thermistor short Check for restricted vent. Replace thermistor to Thermistor open Check for restricted vent Replace Thermistor do Door Open Check connections. Replace door switch. FE Power Source Frequency error Check power source dF Door circuit failure Check wiring to door switch. Replace door switch hE Heater error Restricted vent. Replace thermistor. bE Button Error Check and / or replace PCB od Over dry Sensor Bar open. Adjust time up excessively. Et eeprom failure Replace Eeprom
hE Heater error Restricted vent. Replace thermistor. Heater error
Clean vent and replace thermistor.
Clean all vents from outside all the way to the blwer housing. If you dont get all the lint it will cause this to happen again.
If you need further assistance please feel free to contact.
Jul 24, 2011 | Samsung WF203ANW Front Load Washer
974 people viewed this tip
Top Dryers Experts
