Tip & How-To about Microsoft Windows 8.1 - Windows
How to convert thumbnail into ICONS in windows 8 interface
First time I installed windows 8 i faced that problem that in place of icon it was showing only thumbnail. So here goes the solution to convert thumbnail into icons in windows 8 interface-
Open up the folder with the pictures and click on the View tab
Next click on Options to the far right
Then Click on Change folder and search options
This opens up an options menu
Navigate to the view tab
uncheck the box that says Always show icons, never thumbnails
And Check the box that says Display file icon on thumbnails.
This should solve the problem. It worked for me.
Microsoft Windows 8.1 - Windows Logo
How do I remove a tumbnail from a photo?
Once you've added you're photos, you can set a different photo to act as thumbnail (the programme automatically chooses the first photo/slide, indicated by a little green ticked box sign).
To change the thumbnail to a different photo, highlight the photo you want as thumbnail by clicking it - the frame will change to yellow - and then click on the green ticked box command ("Set Thumbnail") at the top of the window.
You cannot alltogether delete the thumbnail, because every slide show you create needs to have a thumbnail to link the slide show to the menu screen at the start of your DVD. So, on your menu screen there will always be at least one thumbnail. (The black thumbnail that appears in the middle of your screen when you first open the programme, is a "place holder". It needs to be there and it cannot be deleted. Once you've created a slide show, it will be replaced with the photo you have chosen to be the thumbnail. Every time you create a new slide show, a new thumbnail will be added to your menu screen. The position of thumbnails can be changed, using the second ("Edit") Tab.
You will find a User's Guide on the install disc. It can be accessed by inserting the install disc and clicking on the relevant link, or you can right click on your CD/DVD drive (in "My Computer") and then click on "Explore" to look for it on the install disc - it's a pdf file.
Jan 27, 2011 | Individual SlideShow Expressions
No Video Thumbnails in Windows XP
Open folder containg files then click view and select thumbnails
Jul 30, 2009 | Microsoft Windows Vista Ultimate Edition
viewing pictures..
press the view button itself to change views
May 09, 2009 | Microsoft Windows Vista Home Basic Edition
Thumbnails not showing in Explorer in Windows Vista
In the Advanced System Properties when you right click on (My) Computer, you probably set the Performance Settings to "Adjust for best performance". In there you will see a Custom List of options and "Show thumbnails instead of icons" needs to be checked.
Jun 10, 2008 | Computers & Internet
Thumbnail generation
There is no known software compatibility with adobe premiere and vista. The problem will be that you might have changed any setting in vista for thumbnails. I know vista is much different than windows. So, have a look around at the settings.
Feb 18, 2008 | Computers & Internet
1,017 people viewed this tip
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
