Tip & How-To about Computers & Internet
How to convert FAT32 fmt to NTFS or vise verse...
Often we face problem while shifting data to USB drive or flash drive when the size of the data is big. It is because of the format of the USB or flash drive which is FAT 32. So here goes the way out to convert FAT 32 into NTFS-
How to convert a FAT volume or a FAT32 volume to NTFS
    1.In search of windows 7 or 8 type cmd.
    2.In command prompt write-
    chkdsk j: /f
    3.Then type-
    Convert J: /FS:NTFS
    *REMEMBER HERE J MEANS THE DRIVE LETTER.
Computers & Internet Logo
how to restore delected files from my usb flash drive
Hi, Even I faced the same problem. I have deleted some of the PDF file from my pen drive and luckily I could get all the files from it. I used Yodot File Recovery software and with the assistance of this software I was able to get all the PDF files. Download free trial version of the software if you want to know how to recover a PDF file. It recovers not only PDF file but also all the files present in the drive.
Nov 23, 2012 | Computers & Internet
i have a sandisk 8gb usb stick, I am tryind to copy files from windows xp to it but cant, i keep getting file not specified error. I can copy over small files on to it but nothing big. I know the stick is ok because i have used it on another machine
You need to re-format your Flash Drive. The default is FAT32 which only allows files of up to 4GB to be transfered. If you reformat to NTFS, ANY size file can be copied to your FLASH DRIVE.
WARNING ! ! By reformatting, you will loose ALL your data on your Flash Drive. Good Luck
Dec 12, 2010 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
my usb stick needs to be formatted for pc but i cant
you can try format recovery software like asoftech data recovery. You can see
Recover formatted files
It tells the steps how to perform format recovery.
If above does not work, you may have to format the usb drive (use quick format), and then use above mentioned software to scan again the usb drive and recover your files.
Apr 04, 2010 | Computers & Internet
feke usb size
When the flash memory USB hard drive device appears to malfunction it maybe possible to restore it by reformatting it. Insert the flash or USB hard drive into the USB port then Click on Control Panel - Administrative Tools - Computer Management - Disk Management.
Then right click on Disk 1 removable drive and click Format. After the flash drive has been formatted it will indicate that it is Healthy.
Mar 21, 2010 | SanDisk 1GB Cruzer Titanium USB Flash...
Sandisk 16 GB USB Drive wont accept large files says disk is full
What is the USB drive formatted as? Look in My Computer then right click the USB drive, select Properties. See what it says under "File System". My guess is the drive is formatted as FAT32. Now FAT32 has a size limitation of 4GB for a single file, which would explain the error. To get over this you need to reformat the USB drive as NTFS. Then it will accept the 6.95GB file. You can format the drive by right clicking it again and selecting "Format" ... choose NTFS from the drop down menu. Be aware that any data already on the drive will be wiped by the format so be sure to back it up before formatting.
Dec 31, 2008 | Computers & Internet
1,166 people viewed this tip
David Payne
David Payne
