Tip & How-To about Landice Exercise & Fitness
OS or O5 Error on Landice L-Series Treadmills
Probable Cause
An OS or O5 error on the Landice L-Series treadmills, such as the L7, L8 and L9, indicates an over speed condition and this occurs when the actual speed of the running belt is faster than the set speed. The possible causes for an overspeed, OS or O5, error are: A) User weight is over 200lbs, treadmill elevation is set between 10% and 15% grade and speed is set between .5 mph and 3 mph
B) User is pushing against treadmill belt causing it to go faster than the set speed
C) Defective lower board or misaligned speed sensor
D) Maladjusted speed potentiometer
Corrective Action
A) Gravitational force will enable the user's weight to move the treadbelt faster than the set speed. The speed sensor will pick up this increase in flywheel speed and sends this information up to the display electronics. The microprocessor will then compare the actual speed to the displayed speed, determine a runaway speed condition and shut the treadmill down. An overspeed will display in the window. This is a safety feature built into all treadmills that utilize closed loop speed circuitry. The way to address an over speed condition due to gravity is have the user decrease elevation below 10% or increase the speed.
B) Similar to the gravitational force, a user can be holding onto the handrails and pushing the running belt in such a manner where they are using the treadmill like a manual machine rather than a motorized one. User needs to set speed compatible for their actual walking or jogging speed so they are not pushing the belt.
C) It's possible a blown motor control board is the problem. This occurs more frequently with PWM drives than SCR drives. However, this problem is becoming rare due to the PWM circuitry which senses this condition and shuts itself down before the drive motor receives any DC voltage at all. This means you'll get an LS or L5 error if your PWM is blown, not an OS or O5 error. This is a safety feature on all Landice home treadmills with PWM motor control boards. The SCR motor control boards also have internal protection to prevent an over speed condition from occuring due to an internal component failure. In the rarest of cases, on home treadmills, a faulty relay board can cause an OS or O5. To verify this, using a digital voltmeter, with treadmill turned on, measure the DC voltage between the V+ and P1 on the PWM board. The reading should be between 6-7 VDC. Also measure the DC voltage between P1 and P2 on the PWM board. The reading should be between 0.5 VDC and 6-7 VDC. If either of these voltages measure zero, replace the relay board.
D) Get into Open Loop Speed mode and check the speed. Adjust pots as necessary to bring up correct speed for max and min.
http://www.sportsmith.net/support.aspx?did=BAB0DA9A-857E-41B3-A1DD-3DC0663BB9A4
Exercise & Fitness Logo
how do i fix an landice l8 trainer l5 error
that is a loss of speed error. you only get rid of it when the belt starts moving again
Jul 22, 2014 | Landice L8 80 LTD Executive Trainer...
landice L8 has an L5 error displayed wont start up
is a speed sensor problem or the card connectors are wired specifically where the motor wires, sometimes that part is too hot and breaks the solder
Jul 19, 2010 | Landice L8 LTD Cardio Trainer Treadmill
Landice L7 motor voltage in wet conditions
What do you think--what changes when something happens???
Sep 19, 2017 | Landice L8 LTD Cardio Trainer Treadmill
I have a Landice L8 and the error code L5???
LS Error on Landice L-Series Treadmills with Belt Movement Probable Cause A LS error on the Landice L-Series treadmills can also look like L5 and this error code means there is a loss of speed signal. This error can occur with belt movement but speed will not increase. Causes for the LS or L5 error with belt movement are:A) Speed sensor is out of adjustment
B) Speed sensor is damaged or faulty
C) Display cable is damaged or faulty
D) Improper speed control wiring Corrective Action A) Speed sensor should sit parallel with the flywheel and gap between speed sensor and flywheel should be within 1/16". Adjust speed sensor if necessary.
B) Inspect speed sensor connector to relay board. Check for pushed pins or loose wires. Repair or replace speed sensor assembly if necessary.
C) Inspect upper harness or display cable connector to relay board. Check for pushed pins or loose wires, giving specific attention to pin 5 (brown) and pin 9 (green). Repair or replace display cable if necessary.
D) Inspect speed control wiring:
  1. Checking purple wire from V+ on pwm board to P3 on the relay board
  2. Checking orange wire from P1 on pwm board to P1 on the relay board
  3. Checking brown wire from P2 on pwm board to P2 on the relay board
  4. Confirm P3 on pmw board has no connection
Correct speed control wiring if necessary.
Details about LS Error on Landice Series Treadmills with Belt Movement
Jul 09, 2009 | Landice L8 LTD Cardio Trainer Treadmill
Landice treadmill 05 error code comes on when i hit start
Jun 28, 2009 | Landice L8 LTD Pro Sport Trainer Treadmill
528 people viewed this tip
Top Landice Exercise & Fitness Experts
Howard
Howard
lloyd cole
Dave
Are you a Landice Exercise and Fitnes Expert? Answer questions, earn points and help others
