Tip & How-To about Dishwashers
Bon Home DDR100WH
I was frustrated when this dish rack stopped working to dry our dishes. It's quite an item but they have a high failure rate.
It turns out the achilles heel is the on-off button which, in many cases either needs to be replaced or re-situated seeing that it's just held in place with some hot glue.
If you're anxious about disassembly here's what it looks like on the inside.
ujh3ecspuynmm-5-0_1.jpg" alt="25634680-lbbjkx4baojujh3ecspuynmm-5-0_1.jpg">
The top is off and the inside is cleaned with some H2O2.
You can clearly see the heater towards the back.
In the front, covered by 4 screws and a panel is the on-off switch.
Here you can see the panel covering the on-off switch with the button that gets pressed with a plastic arm and the printed circuit board held in place somewhat flimsily with hot glue between the thin plastic supports.
It's a recipe for trouble, especially when people push the outer plastic button really hard.
ujh3ecspuynmm-5-6_0.jpg" alt="25634680-lbbjkx4baojujh3ecspuynmm-5-6_0.jpg">
Here's a look at the inlet in the back. I don't think there's much to do here cleaning wise. This is where the dish rack breathes (inhales).
Line up the tabs to re-assemble. (pointed out by pointed fingers).
A nice look at the uncovered heating coil and fan area.
ujh3ecspuynmm-5-21_0.jpg" alt="25634680-lbbjkx4baojujh3ecspuynmm-5-21_0.jpg">
On the bottom of the rack the screws are pretty easy to find.
Good luck getting yours to work again. Have patience. The button is finicky and may need replacement, or you may need to just lube the plastic outer piece that slides as you push it with your finger to turn the tray on and off. Cheers.
Dishwashers Logo
wy is top rack not washing
top rack is for small plates & cups not pots & pans as they may obstruct the rotating of the sprayer & foul the water from getting to all the items
Aug 31, 2014 | Bosch Dishwashers
How does a warm air dish rack work?
It blows hot air onto the dishes to dry them faster. generally there is a microprocessor that automatically sets the drying time. usually comes with an automatic turn off if overheated button.
Aug 05, 2013 | Home
kenmore 3380957 rev a won't get dishes clean
Make sure that that upper arm is free to turn. Check it while you have dished installed, because sometimes, dishes on the lower rack may stick up too high and hit it. Otherwise, check the back of the water-supply tube attached to that upper rack.... Is it lining up with the water feed port or hole at the backof the dishwasher? Is there a gasket that is either ripped or missing? And check that wash arm carefully.... Might it be split or bent? Are the holes on the bottom clear? (Those holes are usually angled to push the arm around; if they are clogged, the arm won't rotate.)
If you need further help, reach me via phone at https://www.6ya.com/expert/ronald_e6b9572cebe3ad27
Mar 15, 2012 | Kenmore Dishwashers
water not heating up and not drying
Hello
If your dishwasher is not heating properly, troubleshoot the issue. You can often repair this problem and eliminate service fees.
Incoming Water
Most manufacturers recommend that the water coming into your dishwasher be at least 120 degrees Fahrenheit. If the water is too cold, then your dishes don't clean properly. Or the dishwasher must run longer to heat up the water. Test the water temperature by running the hot water on your faucet for about 2 minutes or until it gets really hot. Place a waterproof thermometer under the water. If the water is too cold, increase the water temperature setting on your water heater.
Thermostat
The thermostat is responsible for regulating the water and drying cycle temperature. If this thermostat isn't working, the heating element at the base of the dishwasher tub may not come on. Test this element by selecting the hottest temperature setting. Run the dishwasher on the shortest cycle. Let the dishwasher run for a few minutes, and open it up. If the dishwasher water is not hot or the drying cycle isn't starting, order a new thermostat from a parts dealer since this component is difficult to fix.
Heating Element/Drying Fan
The heating element heats up the water and air. Access this element by removing the bottom rack. It looks like a long black rod. If any part of this component is broken or corroded, you must order a new one. You usually cannot fix this element. The drying fan is located in the main housing of the dishwasher, and it blows air around your dishes to dry them. Check this part by disconnecting the dishwasher from the power supply and opening up the housing. Examine the fan, and see if any dirt or debris is preventing it from moving. Clean it. If the fan won't turn at all or if the motor is burnt out, order a new fan since it's difficult to repair this part.
Additional Concerns
If your dishwasher isn't drying your dishes properly, see if you have selected a heated drying cycle. An air drying cycle doesn't completely dry your dishes. Never overload the dishwasher, as this prevents heat from circulating around your dishes, keeping them from drying properly. Plastic and Teflon dishes don't usually completely dry. You must towel-dry these items.
Sep 12, 2011 | Bosch 24 in. SGS43C12 Classixx...
Instruction for the top dish rack were missing from my order. The rack is for Whirlpool quiet wash plus dish washer. Do you have the instructions?
The top rack is generally for things like glassware, bowls, cups, saucers, and plastics items. Smaller and more fragile pieces go on the top, bigger items on the lower rack. This is the general rule for all dishwashers.
Oct 13, 2009 | Dishwashers
1,334 people viewed this tip
Top Dishwashers Experts
