Tip & How-To about HP Officejet Pro 8600 Premium e-All-in-One Wireless Inkjet Printer
HP 932 933 950 951 Refilled Ink Cartridge Usage
If using refilled HP 950, 950XL, HP 951 or HP 951XL ink cartridges you observe an "Unauthorized ink", "non-genuine ink cartridge may affect warranty", "counterfeit ink" or similar message, you can simply ignore/dismiss these messages by pressing 'OK' once for each cartridge, so that the printer resumes its normal operation. Customers who have questions regarding the use of refilled ink cartridges can visit http://www.inkjet411.com Alternatively, if a refill center is not close to you and you need to purchase a new ink cartridge(s) and are trying to cut costs, we suggest you try a remanufactured ink cartridge from http://www.inkplicity.com/ as their ink cartridges typically have the lowest cost in the USA, have a high reliability rating, come with a 1-year warranty and provide free shipping for all orders above $20 (available for US Residents only). Inkjet411 Team Member ---------------------------- Video: http://www.youtube.com/watch?v=Y0XJnUUht_8 ,
HP Officejet Pro 8600 Premium e-All-in-One Wireless Inkjet Printer Logo
how to reset hp 901 ink
When you get an HP integrated ink cartridge refilled (i.e. HP 60, 61, 74, 75, 901, 92-98....currently offered by Costco and Frys today) or if you buy a remanufactured/compatible HP ink cartridge, the ink levels CANNOT be reset (HP has a smart chip embedded within the nozzle plate at base of ink cartridge which counts the drops and then registers as empty - it uses fusible links so the electronics are literally blown - thus non-reversible).....so you just need to live with the low ink messages and ignore ink low, non-genuine, counterfeit, fraud messages and similar while you are using these types of refilled or aftermarket ink supplies.
Refer to Inkjet411.com sitelet for all printer models which use refilled ink cartridges (most major brands and models) - see videos below on HP 901 and 901XL low ink warning messages, along with all the other more severe error messages:
http://inkjet411.retailinkjet.com/
Jul 24, 2012 | HP OfficeJet J4580 All-In-One Laser...
I GOT MY INK (NOT LEXMARK ) AND MY PRINTER WON'T PRINT. THEY ARE THE CORRECT AFTER MARK CARTRAGES.. JIM
Lexmark does not recommend the use of refilled or unauthorized cartridges. These tend to degrade print quality and cartridge/printer performance. I would highly recommend you replace your non-Lexmark cartridges with new genuine ones.
Sep 23, 2011 | Lexmark C533DN InkJet Printer
our printer is a hp 7200 ,refil ink cartridges, and because we didn't use hp ink all printing is shut down, can you help? Thank you ****
Unfortunately there is no work around for this.
All HP printers requires genuine HP ink cartridges,also refills are not allowed.
HP ink cartridges has a mechanism only compatible with HP printers that sends a signal to the machine when a non HP ink cartridge is used. I highly suggest you use a genuine HP ink cartridge, there is also a high chance if that your printhead or printing mechanism might be damaged.
Check for ink leaks right away, also make sure to clean the printhead with lint free cloth and use bottled water only. Make sure not to touch the electrical contacts found on the bottom of the print head.
Jun 25, 2011 | Office Equipment & Supplies
Just installed refilled black ink cartridge on hp
By using refilled cartridges you will always have this problem. Each cartridge has a chip that lets the printer know when it is full or empty. By pressing the ok button you may be able to clear this message. However, most of the time you can still be able to print and ignore the message.
May 28, 2010 | HP Deskjet D4260 Printer
Is it possible to use non HP ink in ths printer? Tried using "remanufactured ink", and concluded that this printer may be programed to block the use of NON HP INK.
It is always recommended to use genuine HP cartridges.
As if we will use the non HP or refilled cartridges, it will reduce the life of the printer.
And we will get an error "cartridge problem".
Plaese use the below cartridges, which are compatible with this printer.
HP 02 Black 660 pages
HP 02 Black Twin Pack 1320 pages
HP 02 Color Combo See single 02 inks
HP 02 Cyan 400 pages
HP 02 Light Cyan 240 photos
HP 02 Light Magenta 240 photos
HP 02 Magenta 370 pages
HP 02 Photo Value Pack 150 photos
HP 02 Yellow 500 pages
HP 02XL Cyan 600 pages
HP 02XL Magenta 555 pages
HP 02XL Yellow 750 pages
Apr 10, 2010 | HP Photosmart C5180 All-In-One InkJet...
733 people viewed this tip
Top HP Audio Players & Recorders Experts
Lawrence Oravetz
richie46
Are you a HP Audio Player and Recorder Expert? Answer questions, earn points and help others
