Tip & How-To about Dyson Vacuums
Best Upright Vacuum You Can Buy!!
Paying a high price for a vacuum does not translate into best performance. My daughter purchased a Dyson (over $700.00) and after considerable goading, she accepted the challenge I had posed. Clean her carpet with her Dyson until she was satisfied that it was clean and then use my Kenmore SensorClean (no longer available by that name and over 10 years old) over the same area and see the results for herself. After the test, she stated she could feel the difference on her bare feet and immediately purchased the Kenmore Elite Bagged Upright Vacuum Cleaner ($279.00). The Dyson is now collecting dust (on the outside). With a build-in fiber-optic dirt sensor, you don't have to guess when the carpet is clean, the vacuum lets you know via the lights. Its suction power is second to none, the extra long cord lets you cover more area without having to change outlets and the direct-drive means no belts. You have 30 days on any purchase to return it, so try it for yourself, you may soon be purchasing a new vacuum that is worth every penny.
Vacuums Logo
Dyson DC 25 wont turn on
Why does your daughter think that? While a whole house surge protector is something I can't recommend enough, it's highly unlikely that the average power surge would take out a vacuum. The usual suspects are not plugged in all the way, the filter has never been cleaned, the cord has a tweak, break or is exposed somewhere or the vacuum's fuse blew (if it was a power surge, that's where you'd want to look.
Your owner's manual should have instructions for changing the fuse, if not, take it to a certified Dyson service store and have them check the fuse for you. :)
Jul 05, 2016 | Dyson Vacuums
bad or good
Shark-hear the prices have come down . Work very good.
Jan 12, 2016 | Vacuums
dyson vacuum power cord
Hello, this is Ava with Think Crucial.
You may purchase your Dyson Power Cord from us using the link provided below.
Dyson DC07 DC14 DC17 DC18 DC25 Replacement Power Cord Part 905449 02
You can purchase a wide variety of high quality Dyson replacement parts for your Dyson Vacuum direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
https://www.thinkcrucial.com/search?type=product&q=dyson
I hope this was helpful.
Ava B.
Think Crucial Customer Care
http://www.thinkcrucial.com/
May 01, 2012 | Dyson Ball DC24 Bagless Upright Vacuum
Brush bar is scratching hardwood floors. It seems too low!
There are a number of reasons why your brush roller is not working properly. General maintenance to your vacuum is crucial and will help it work at peak performance.
First things first lets focus on the brush roller. Unplug the vacuum and turn it on its side. Look for any noticeable clumps of debris or hair strands that may be caught in the brush roller. Remove these obstructions, probably best to do so with a scissor if it's hair or long pieces of carpet fibers. After removing the debris try manually rotating the brush roller to uncover other hidden clogs. Another thing to take note of is the condition of the bristles on the roll itself. Are they loose or worn down? These are signs that your brush roller is in need of replacing.
While checking out your brush roll you might as well take a look at your vacuums belt. Your belt should be replaced about every three months. After regular usage, the belt will stretch out, lessening the tension on the brush roller. Lesser tension diminishes the brush roller's turn rate and speed. If the belt feels loose then it certainly is affecting your vacuums suction as well as your brush roll not moving at all.
Ava B.
Mar 31, 2010 | Dyson DC07 Animal Bagless Upright Cyclonic...
Dyson Ball makes high pitched noise
To fix any noise issues that your Dyson vacuum gives, a proper maintenance will do the trick. Most of the time , cleaning the filters, checking for blockages and clearing the passageways will eliminate the noise. Please refer to your operational manual how you can do this.
Ava B.
Oct 04, 2009 | Dyson Vacuums
1,222 people viewed this tip
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
