Tip & How-To about Bernina Sewing Machines
Bernina 530 through 830 Record Oiling Diagram
Photo shows location of oil holes for Bernina 530-830 Records.
Sewing Machines Logo
Where are the carbon brushes located on a Bernina sewing machine located? It is a Bernina Record 730, B2-730, EPI 2 - 40 -0803, 85/37 W 7250/min. Thank you.
THE MOTOR USUALLY HAS A LARGE SCREW. WHEN YOU REMOVE THE SCREW THE CARBON BRUSHES WILL SHOW. THERE IS USUALLY TWO. YOU CAN TAKE THEM TO A LOCAL MOTOR SHOP TO GET NEW ONES.
Dec 26, 2014 | Bernina Sewing Machines
My wheel will nor turn and my machine will not sew on my 930
sounds like it's time to have the sewing machine serviced.
Feb 07, 2013 | Bernina Sewing Machines
Bernina Record 930 Electronic, seldom use, like new. Wheel will not move. Was doing stright sewing, machine slowed down then froze. Maching is clean. No instruction book or manual. Machine belongs to my elderly mother who cannot locate manual.
Bernina 930 Records are notorious for the basting stitch sticking which eventually locks up the machine. To prevent this from happening, be sure to run the basting stitch for a few minutes every month. If it is stuck, you'll need to take it to a Bernina technician.
If it is not the basting stitch, it could be a broken plastic gear (trip to the Bernina technician) or it needs oiling.
If it is not a broken gear, then it probably needs oiling. Your Bernina mechanical requires regular oiling and cleaning even if you don't use it (ie, every time you change the bobbin, every 8 hours of sewing, or every 6 months if not in use). HINT: recommend Bernina oil or similar good quality oil for mechanical machines, NOT 3-in-1 oil, WD-40, or cooking oil!!! One or two drops of oil in every oil hole and every place that metal part rubs against metal part.
Treat your Bernina well and it will serve you well for many years.
Oct 23, 2009 | Bernina Sewing Machines
Oiling Bernina Deco 330
Use only good quality clear sewing machine oil from your Bernina dealer--ask them which is the correct oil for your machine. The likely place to oil is in the hook area (see page 44 of the manual). Be sure to apply a drop or two every 8 hours of sewing time. If you know your machine, you may notice a change in sound when it needs lube. Oiling anywhere else could damage your machine.
Do NOT place lube in any holes (as previously suggested) in the bed or top of the machine. These are not oil ports. They are holes for fastening accessories to your machine, ie circular embroidery unit, binding units, seam guides, etc.
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=1&ved=0ahUKEwi8ubHe6o7XAhXpi1QKHb3zAngQFggxMAA&url=https%3A%2F%2Fwww.bernina.com%2Fen-US%2FSupportData%2FBERNINA-Nah-und-Stickmaschinen%2FBERNINA-3er-Serie%2FManuals%2F0333017104_2014-02_Manual_B330_B350_B380_EN-us&usg=AOvVaw0F7ScSQEEitpxEnDD0v8Y1
Oct 26, 2017 | Sewing Machines
1,430 people viewed this tip
Top Bernina Sewing Machines Experts
Tally Girl
Tally Girl
jnissen
Level 1 Expert
Chris Wetmore
Are you a Bernina Sewing Machine Expert? Answer questions, earn points and help others
