Tip & How-To about Amazon Fire TV Stick
Amazon fire stick reset
Make sure that your wifi is a good signal,if you are using a lower tier internet service then it wont work,call your internet provider and verify that your internet is sufficient,also use 5ghz wifi,not 2.8ghz.
if this doesnt work for connecting then,
reset this way,
straight from amazon,reset firestick,
Please unplug the Fire TV stick from power source and then plug it again after 5 seconds.
Once the Fire TV stick is back on, please take batteries out of the remote and re-insert
also,xfinity remote controls work with firestik tv in place of the original remote,program it for a vizio tv and forget the original remote!
Amazon Fire TV Stick Logo
The tv show or movie loads in Amazon, Netflix, Acorn, etc... I can see it but then it won't play. I can forward it but it still won't play.
make sure that your wifi is a good signal,if you are using a lower tier internet service then it wont work,call your internet provider and verify that your internet is sufficient,also use 5ghz wifi,not 2.8ghz.
reset this way,
Mar 16, 2015 | Amazon Fire TV Stick
i have been on here all night and i still can,t get netflix
download the netflix app,enter your credit card info to buy netflix service,,it should work,also,
reset this way,
Mar 13, 2015 | Amazon Fire TV Stick
it wont let me connect to the internet
You need to check internet connection settings. If you use wifi connection you should in active wifi area ( check signal on your screen). If you use modem as internet connection check the setting ( you may need assistance from service provider. If you use cellular phone as modem, make sure, you have phone's pc suite installed properly on your laptop then paired tehm using firewire.
Regards
May 17, 2011 | Computers & Internet
WL-520GC... wifi signal very good; but no internet connection...
login to the router page and you need to configure your router settings as per your internet service provider then save the settings and reboot your router and check it
Jun 29, 2010 | ASUS EZ N Wireless Router up to 150Mbps...
wifi not function
My Internet service provider walked me through connecting correctly. I had chosen the WEP security options and should have chosen the WPA-PSK option. Call your service provider and get them to help verify your security access codes.
Sep 26, 2008 | Palm LifeDrive Handheld
2,800 people viewed this tip
Top Amazon Televison & Video Experts
Andrew Taylor
Andrew Taylor
bigdawg7299
ray gallant
Are you an Amazon Televison and Video Expert? Answer questions, earn points and help others
