Tip & How-To about Android Huawei
Booting Most Android into Recovery Mode (Hard Resetting)
Usually you can boot into recovery mode by following these steps:
  • Turn off you device.
  • Then, reboot by pressing the Power and Volume Up buttons simultaneously.
  • Keep the buttons pressed for a short while - a few seconds - and then release the same.
  • The recovery mode menu should be displayed.
  • Note: on Samsung branded devices the recovery mode can be entered by pressing the Power, Volume Up and Home buttons at the same time.
But if the procedure from above isn't working for your Android device, then use one of the following methods (the first one is for rooted handsets so be careful and try not to mess things up as you can end up in bricking your smartphone / tablet).
Android Huawei Logo
My tablet toshiba excite pure is saying Unfortunetly, sysyem UI has stopped. It goes off when i push ok and comes right back. How do i remove it?
Have you tried to wipe the cache partition
App data
Step 1 Press the "Menu" button and tap "Settings." Touch "Applications."
Step 2
Tap "Manage Applications," select the "All" tab and touch an application name.
Step 3
Touch the "Clear Data" button to wipe the app's saved data. Tap "Clear Cache" to remove any cached data for the app.
Phone Data
Step 1 Turn off your Android device. Reboot the phone or tablet into Recovery Mode. The process is specific to the device model. For the Motorola Droid, press and hold the "Power" button and the "X" key on the slideout keyboard. Release the "Power" button when the Motorola icon appears. Press the "Volume-up" and "Camera" buttons simultaneously to open the Recovery Console. To access Recovery Mode with the LG Ally, press and hold the "Power," "Home" and "Volume" buttons simultaneously.
Step 2
Press the "Volume-down" button to scroll to "Wipe Data/Factory Reset." Press the "Camera" button to select it.
Step 3
Scroll to and select "Wipe Cache Partition."
Step 4
Highlight and select "Reboot System Now."
Mar 03, 2015 | Toshiba Tablets & eReaders
wipe my data partition
you need to boot into recovery mode to wipe the data partition. Doing this will reset the phone's data partition. Doing this will delete all data off the device and return it to the same state it was in when you first powered it on.
  1. completely power off the phone
  2. press and hold the power, volume up, and home buttons until you see the Samsung logo
  3. use volume up/down to scroll and power to select
  4. scroll to and select wipe data/factory reset
  5. select yes on any following prompts
  6. reboot device
If the above process does not work on your device, see alternate methods to boot into recovery mode in the following link.
How to Boot Samsung Galaxy Devices into Download Recovery Mode
Oct 18, 2014 | Samsung Galaxy Tab 10.1 Wifi - Tablet -...
galaxy tab 2 10.1 does'nt show thw level ef charge
Try Resetting the Device Cache Partition by booting in to Recovery Mode.
o turn ON in Recovery Mode:
Step 1: Power off device completely (You Might need to Keep it on charge)
Step 2: Press and Hold "power" + "Vol up" for 5 sec
Step 3: Notice it flash boot screen twice
Step 4: Enter recovery menu use vol up and down to navigate
Step 5: Press power button for confirmation
Step 6: Wipe cache partition.
if clearing the cache partition doesn't help, you can also try resetting your device by formatting it to factory settings (ALL DATA WILL BE DELETED). for this Repeat the Steps upto 5, then use Step 6: Wipe data and clear cache.
Post Thanks if it helps
Mar 26, 2014 | Samsung Tablets & eReaders
i'm trying to reformat my laptop but it's not booting up in DVD drive..how can i fix this problem..can you me how to do it to boot up in recovery disk?
Hi tech_sup156 ,
Please follow the below steps:-
  1. On the first screen , press Del or F2 when you boot your computer so that you enter BIOS mode.
  2. In Bios mode search for boot mode or boot devices priority and choose the first boot drive as your DVD - RAM drive.
  3. Now save the changes and exit BIOS and you would find the next time you reboot the PC , it will ask you to book from the DVD - RAM drive , only on the condition that the DVD is a bootable DVD , as usually found in case of genuine windows operating system dvds/cds.
Hope this helps , your feedback would be appreciated.
May 16, 2011 | HP Pavilion dv6000z Notebook
901 people viewed this tip
Top Android Cell Phones Experts
Owen Barnes
 steve
steve
Jay Plesset
Are you an Android Cell Phone Expert? Answer questions, earn points and help others
