Tip & How-To about Computers & Internet
All icons On P.C change to internet explorer Solved
1.go to start menu.
2.run command
3.regedit in run command.
4.HKEY_CURRENT_USER\\software\microsoft\windows\currentvershion\explorer\flexts\
5.search for .lnk ext.
6.delete whole .lnk key or delete the user choice key on that.
7 just restart
Computers & Internet Logo
how i can reuse the norton 360 v 4.3.0.5 Its trial period is expired. Plz send me product key or trial reseter. special thanks
Please remove the existing version of Norton program from the control panel, then go ahead and delete all Symantec and Norton files from the computer's C or D drive.
After that, open your registry and first take a back up just in case anything get deleted by mistake.
Then delete all Norton and Symantec files from HK CURRENT USER, HKEY LOCAL MACHINE, HKEY USERS, HKEY CURRENT CONFIG.
You can click on the SOFTWARE folder in each class to find the Norton files if any.
To open your registry editor, type regedit in RUN command (windows key+R)
After that you can again install a trial version of Norton for 30 days.
Feb 05, 2011 | Symantec Norton 360 Full Version for PC...
cd drive not detected
Lets do this.
1. Close all programs
2.Click on Start, Run, and type REGEDIT and press Enter.
3.click HKEY LOCAL MACHINE - SYSTEM - Current control set - control - class - select {4D36E965-E325-11CE-BFC1-08002BE10318} - on the right hand side you'll find upper filters and lower filters entries - right click and delete both(Upper and lower filters) - restart your computer and hope this works for you,
Awaiting response.
Thanks..
Sep 08, 2009 | Acer Aspireā„¢ T180 PC Desktop
windowx xp booting time no icons appear.
Changing the default shell (all users):
1) open regedit (start menu > run, and type in regedit)
2) go to: HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Winlogon.
3) Change Shell from explorer.exe to the new shell path e.g C:\Litestep\litestep.exe
4) log out and log back in.
Changing the default shell (only current user):
1) open regedit (start menu > run, and type in regedit).
2) go to: HKEY_CURRENT_USER\Software\Microsoft\Windows NT\CurrentVersion\Winlogon.
3) add a new string value (Edit > New > String Value) called shell. and set the value to the path of the new shell e.g C:\Litestep\litestep.exe.
http://support.microsoft.com/kb/228309
May 09, 2009 | Computers & Internet
genuine microsoft solve problem
Activate Windows XP Without Registration "
1. Type Regedit on the Run Menu
2. Go to Hkey-Local_Machine/Software/ Microsoft/WindowsNT/CurrentVersion/
WPAEvents
3. Select OOBETimer (Reg-Binary) and Press Enter. Now You will See a Set of 12 Keys.
4. FF D5 71 D6 8B 6A 8D 6F D5 33 93 FD
{just delete D6 (4th entry) and replace it with C4}
5. Exit Regedit.
6. Type "%systemroot%\system32\oobe\msoobe.exe /a" on the Run Menu (without quotes)
7. Select "Yes I want to telephone a customer service representative to activate windows".
8. Click Next
9. Select "Change Product Key"
10. Put these keys
QMDGV-QRC2B-XF6JB-GRGHK-W9DRC
11. Select Update
Dont worry about asking again to register , close that
Restart the system and repeat steps 6 to 11, now the process will tell you that Windows XP is already activated.
rate me
it will work for you 100%
don't forget to reply
Jan 07, 2009 | Microsoft Windows XP Professional With...
210 people viewed this tip
David Payne
David Payne
