Tip & How-To about Coffee Makers & Espresso Machines
The secret how to keep your espresso machine for years
Its like anything in life you got to take care of it cleaning it and the most important decalfication hard water residue kill espresso machine its a big invesrment some cost over 2000 dollard even the less expensive machine can last you a long time use producT to remove hard water residue fill your water tank add the decalsifier start the machine if you got a steam wan open the valve let the water out for 20 second turn the machine off for 15 minute let the decalsifier work and repeat the step 1 untill your water empty after fill the water tank and rinse evething very good dont forget decalsifier is acid so rince the water tank very good the harder your water level is the more often you need to do it 1 decal every 150 liter of water or every 2 to 3 mouth do that and its gonna last you 10 time longer
Coffee Makers & Espresso Machines Logo
When I plug the unit in it says system overheated and I can't get to reset. It also won't take on water
The problem there it is the deposits of water residues, calcium in your heating element! To prevent that and prolong the espresso machine's life I would use filtrated or distiled water. To fix the problem you have to get to your heating element take it out and try to clean it! To clean it u can use white vinegar, and than wash it with clean water!
Good day to you!!!
Jan 13, 2015 | Coffee Makers & Espresso Machines
CAN'TGET WATER TO COME THROUGH
You need to provide more info: machine age; frequency of use; last cleaning; hardness of your water; and anything from your manual that you do not understand or find confusing.
Aug 03, 2014 | Saeco Talea Giro Espresso Machine
water smell
You may have some residue inside the steam pipe from previous uses (e.g. milk). If you know how to remove the steam pipe, this will be easy to clean. Otherwise, you could try a pipe cleaner (depending on the type of steam wand).
You can also try running the steam pipe into some water, but be careful not to overheat the boiler (consult your manual... it may say you can't steam continuously for more than a minute, or even less).
Sep 24, 2013 | Nuova Simonelli Microbar Espresso Machine
A puddle of water forms under the machine and
Hi
If its dirty water your drain in back is plugged. There is a pocket below the injector nozzle that the pressure is relieved in when the brewing is done. This pocket can get clogged with residue after a while and then overflows under the drip tray. The drain is in back just above the back of the drip tray. If you pour water in the pocket it should come out the drain. If it doesn't, clean out the pocket, and that should take care of it. If it does,t, I need more information.
Oct 30, 2009 | Saeco Vienna De Luxe Espresso Machine
it leaks at the drain outlet behind the brew group...overflows into the tray and leaks horribly from underneath unit
Hi
The drain in the back of the machine is plugged with coffee residue. There is a pocket below the injection tube ( the one with the 2 o-rings on it) that is filled with coffee residue that needs to be cleaned out. When its clean and you put water in the pocket it should come out the drain hole into the drip tray. The pocket is where the brew unit relieves the pressure when it is done brewing. That is why you get coffee residue in the pocket.
Oct 11, 2009 | Saeco Vienna De Luxe Espresso Machine
259 people viewed this tip
Top Coffee Makers & Espresso Machines Experts
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
