Tip & How-To about Televison & Video
How to program Chrysler Remote Transmitter
A Chrysler Transponder Key once programmed into a one car cannot be programmed to work any other car.
The transponder code identification is learned by the Sentry Key Immobilizer Module during programming. The Sentry Key Immobilizer Module sends the "Secret Code" to the transponder key and is retained by the transponder key during programming. After programming of the transponder key identification to the Sentry Key Immobilizer Module and the Secret Code is exchanged, the Sentry Key Immobilizer Module will ask for the transponder identification and the Secret Code every time the key is turned to ON or START.
No Emergency "Start" procedures for Chrysler vehicles.
Chrysler Key Operation and Programming
Model: 300 Year: 2005 - 2008
Model: 300C Year: 2005 - 2007
Remote alarm / central locking
System Operation
  • Pressing key LOCK button activates alarm and central locking.
  • Pressing key UNLOCK button once deactivates alarm system and unlocks driver's door.
  • Pressing key UNLOCK button twice within 5 seconds deactivates alarm system and unlocks all doors and trunk.
  • Pressing trunk lid button twice opens trunk lid.
  • System will automatically lock all doors when vehicle is driven above 15 mph.
  • Additional functions can be set to respond to the transmitter.
Programming
When
  • Key transmitter added or replaced.
How
  • Key transmitter is programmed during immobilizer programming procedure.
Immobilizer
System Operation
  • Switch ignition ON.
  • Immobilizer warning lamp illuminates for approximately 3 seconds.
Programming
When
  • Keys added or replaced.
How:
NOTE: Two programmed key transmitters must be available for the following procedure to operate. If none available key transmitters can only be programmed using diagnostic equipment.
  • Insert first programmed key into ignition switch.
  • Switch ignition ON for at least 3 seconds but no longer than 15 seconds.
  • Turn ignition OFF and remove key.
  • Withing 15 seconds insert second programmed key into ignition switch and turn ignition ON.
  • After 10 seconds an acoustic signal will be heard and immobilizer warning lamp will flash.
  • Turn ignition OFF and remove second programmed key.
  • Within 60 seconds insert non programmed key into ignition switch and turn ignition ON.
  • After 10 seconds an acoustic signal will be heard and immobilizer warning lamp will illuminate for 3 seconds.
  • Switch ignition OFF.
  • Remove Key.
Check operation of programmed key transmitter.
Repeat procedure for additional key transmitters if required.
Model: 300M Year: 1999 - 2003
Model: Concorde Year: 1998 - 2003
Model: LHS Year: 1998 - 2001
Model: PT Cruiser Year: 2000 - 2005
System Operation
  • Pressing remote transmitter UNLOCK button once deactivates alarm system and unlocks driver's door only.
  • Pressing remote transmitter UNLOCK button twice within 5 seconds deactivates alarm system and unlocks all doors.
  • Alarm / Central locking functions can be altered using remote transmitter.
Programming
When
  • Remote transmitter added or replaced.
How:
NOTE: One programmed Remote transmitters must be available for the following procedure to operate.
  • Obtain all remote transmitters.
NOTE: Any existing remote transmitters not used during programming will become inoperative.
Using a programmed remote transmitter proceed as follows.
  • Press and hold remote transmitter UNLOCK button.
  • After holding the UNLOCK button for at least 4 seconds but no longer than 10 seconds, press remote transmitterPANIC button for at least 1 second and release both buttons.
  • Ensure acoustic signal is emitted indicating programming mode active.
  • Within 30 seconds carry out the following procedure for each remote transmitter (including previously programmed remote remote transmitter)
  • Press any button of each remote transmitter to be programmed.
  • Ensure acoustic signal is emitted after each remote transmitter operation.
  • Programming must be completed within 30 seconds.
  • Switch ignition OFF or wait 32 seconds to exit programming mode.
Ensure final acoustic signal is emitted.
Replacement remote transmitters can also be programmed using diagnostic equipment.
Immobilizer
System Operation
  • System arms after switching ignition OFF.
Programming
When
How
NOTE:Two programmed key transmitters must be available for the following procedure to operate.
  • Obtain all keys.
  • Using first programmed key turn ignition switch ON and wait 3 seconds, return to OFF position and remove key.
NOTE: First and second programmed key operations MUST be performed within 15 seconds.
  • Insert second programmed key and switch ignition ON.
  • Wait approximately 10 seconds.
  • Ensure immobilizer warning lamp begins to flash and an acoustic signal is emitted.
  • Switch ignition OFF and remove key.
  • Within 50 seconds, insert new key and switch ignition ON.
  • Ensure acoustic signal is emitted and immobilizer warning lamp remains illuminated for 3 secondsindicating programming completed.
For each additional key repeat procedure starting from the beginning.
Replacement keys can also be programmed using diagnostic equipment.
Automotive and Commercial Locksmith Chrysler Remote Control Programming...
Televison & Video Logo
Bought car at auction- no keys. Had key made at GM dealer. Programmed key- key works. Car wont start- Codes are P0633 and P1629. cannot clear codes
DTC P0633 : Theft Deterrent Key Not Programmed
When learning the pre-release password, as well as the challenge and response sequence, the engine control module (ECM) is placed in learn mode. DTC P0633 will set automatically as an indicator that the system is in learn mode and not as a fault indicator. Once the password and challenge/response are learned, learn mode will be exited when the engine is successfully started. At this point, the DTC will be cleared. If the ECM does not exit learn mode, P0633 will remain current and indicate a fault.
The "key" referenced in the DTC descriptor does not refer to the vehicle key. In this case, "key" is referring to the challenge response.
DTC P0633 requires a successful engine start to exit the learn procedure and clear the DTC. If an unrelated malfunction exists that causes engine starting to be disabled or otherwise unavailable, learn mode will not exit and DTC P0633 will remain current. In this situation, the cause of the inoperative engine starting must be corrected before diagnosing DTC P0633.
DTC P1629: Theft Deterrent Fuel Enable Signal Not Received
The theft deterrent module (TDM) sends the pre-release password to the engine control module (ECM) via the serial data circuit. The ECM then sends a challenge to the TDM. Both the ECM and TDM perform a calculation on this challenge. If the calculated response from the TDM equals the calculation performed by the ECM, the ECM will allow vehicle starting.
DTC P1629 is an indicator that the challenge response was not received within the required 2 second window. This does not necessarily indicate a fault is present with the TDM or ECM. Factors such as a long engine crank, a delay in the serial data communication, or B-codes set in the TDM will cause DTC P1629 to set. This DTC should not be used as a fault indicator, but rather as a symptom to assist in the diagnosis of these other systems.
Who checked the codes , you -dealer ? You need to have BCM checked for codes B - codes ! you need a up scale diagnostic scan tool for that , dealer Tech -2 !
DTC B3935 57 : Transponder Authentication Error
DTC B3976 46 : Unconfigured Transponder/Vehicle Configuration Not Programmed
DTC B3060 : Unprogrammed Transponder Identification Code Received
DTC B3055: No Transponder Modulation or No Transponder
DTC B3031: Security System Controller In Learn Mode
Aug 07, 2015 | 2006 Buick Lucerne
how toprogramm car key toyota matrix
  • 1 First you will need to purchase a blank Toyota transponder key. You can do this from the dealership, a locksmith, or an online source such as eBay. Once you have the key, take the blank key and the master key to a locksmith that he or she can duplicate the key. This will be much cheaper than the dealership.
  • 2 Now that you have the newly cut key and the master key, you can program the Toyota transponder key. Sit in the driver's side of the Toyota vehicle. Press and release the brake and gas pedal simultaneously.
  • 3 Insert the master transponder key. Do not turn it. Push and release the gas pedal 5 times within at least 15 seconds of inserting the master key.
  • 4 Press and release the brake pedal 6 times within 20 seconds of completing step 3, then remove the master transponder key.
  • 5 Insert the newly cut transponder key into the ignition, but do not turn. Press the gas pedal once.
  • 6 Wait up to 2 minutes or whenever the security light on the dashboard turns off. Once the light goes off, remove the new transponder key and press the brake pedal once. The new transponder key should now be programmed. Test the key by attempting to start the engine. If the engine does not start, repeat the steps above.
  • Mar 02, 2015 | 2010 Toyota Matrix
    how do you replace a lost key for a lexus rx 330
    You need to bring the VIN (Vehicle Identification Number) to a Lexus dealer, where they will check that against a stolen car database, and ensure you receive the correct key. This key usually has an internal transponder-computer chip to match the vehicle. Not inexpensive but there's pretty much no way around this.
    Hope this helps.
    Mar 19, 2010 | 2004 Lexus RX 330
    My remote start will not work. The engine starts
    It is probably the transponder bypass. Try this: Put a key in the ignition (do not turn on or to acc, just put it in) and hit the remote starter remote. If it starts, your transponder bypass is bad. I had this same problem. I have not been able to find just this part from Chrysler (you might).
    You can purchase two types of bypasses. One actually uses a transponder key inside. The other is a computer chip that is programmed just like the transponder key. Your choice. Just do a search for "transponder bypass" and do a little research.
    I used the TBKIII. Key & unit added up to $21.00. However, it only works with remote start. If I try to start with the key, it shuts down because it is picking up the key and the key in the bypass. Unit has a bypass for this, but I still have not found the correct answer to make it work. Good luck.
    Mar 01, 2010 | 2005 Chrysler Town & Country
    how to reset my factory car alarm in a 1999 mercury cougar v4 2.0? thanks
    1999 cougar. before they tell me I need a fuel pump I want to be SURE the anti theft system has not shut off the fuel to the engine.
    how do I confirm that?
    Dec 08, 2008 | 1999 Mercury Cougar
    813 people viewed this tip
    Top Televison & Video Experts
    Electro Med Services...
