Tip & How-To about HP Computers & Internet
HP OMNI 100 AIO
There are 2 little problems with the hp omni 100 all in one , the first is if the unit is unable to boot to bios you can reset the bios by moving the blue jumper located next to the ram over 1 position for 10sec or so then move it back to the first position , the other is you need a temperature measuring software for the GPU mainly when watching hd movies of playing games that use the 3d side of things as the ventilation for the heatsink is enclosed and not venting outside , it does help if you leave the panel off , this is a design fault and will lead to GPU problems over time .
Computers & Internet Logo
My up omni 100 desktop pc goes black and then will not come back on unless I unplug power for at least 10 minutes, then sometimes it will power back on to where I left off on the Internet, but is not
Just a guess I think ur cpu is overheating turn on pc and press whatever key it says on screen to enter setup wen you have done tht look for pc health option and check to see if cpu is getting hotter it should be stable between 30-50 degrees it will shut down automatically in 90 degrees or above if it is doing that you prbbly need more thermal paste between cpu fan and cpu underneath the fan be care full not to spill any into the cpu thts the brain of the computer go to youtube to see how to do this there might be a few videos on it if you feel you don't want to risk doing it yourself bring it to repair shop... Hope this helps
Dec 26, 2014 | HP Omni 100 PC
my omni will not power on blank screen only
Hi Julie,
Have you checked all your connections? Where there any odd smells such as burning or anything of that nature? Any sounds when it starts to boot up?
Sep 02, 2013 | HP Omni 100 PC
hp omni 1`000 all in one computer wont fully boot into windows
a desk top PC?, what is it? use full names of things.
you never said what the screed did, is it black all the time.
if yes, does BIOS screens work?
F11 key, (the magic key) on older HP its F10 older still (none)
what year PC is this, full model number , type it out full off the service tag.... i cant guess omni this is. there are 29 models and subs.
The newer HP systems, all have this F11 key
this is the magic key as you boot, you hit it fast (tap tap tap)
and it goes in to recover mode. My 2006 Laptop does.
the HDD if still working and corrupted,
will run the virtual installer disk, via a hidden partition on said HDD>
if that is confusing, try to imagine 3 ways to install.
F11
HP recover disk called the media kit. (uses on replace HDD )
MS disks, wrong, and will fail., ask how if must,,,,
if you and gone to HP forum or the support page
you'd have seen there is may different omin100s, lots
sorry cant guess yours...
you asked for help and cant muster up the service tag words
full model at least.
if you had id have pointed to the page that tells you what to do step by step, at HP.com
even what to do when it dont boot,all ways from SUNDAY.
the oldest one supported is 2010 year.
here is 100-5000 omni ,series, many in series.
https://support.hp.com/us-en/product/hp-omni-100-5000-desktop-pc-series/4273707/troubleshooting
and last
no start actual pages... i see it covers most ways, (weak on hardware causes, there are vast cause under that topic, ask)
https://support.hp.com/us-en/product/hp-omni-100-5000-desktop-pc-series/4273707/document/c01884928
Jun 21, 2017 | HP Omni 120-1125 20" All-in-One Desktop PC
hp omni 100 all in one takes 4 hrs to boot and says unable to bootwill
some came with W7 others W8, yours came with W8
or did you down grade it wrong, like many did, hating W8?????
4 hours to boot. sounds like >....
(bad HDD, or infected OS, or you
"AMD Fusion E450 (Zacate) Dual Core processor soldered down on the motherboard"
the F11 key at power on , runs the restore W7 partition !
if w8 new, then w8 now, if you down graded it, IT WILL FAIL>!!!
Ill pretend W7 day 1, new
Ill pretend , you never once used MS, media here of any kind.
NO MS ISO.s or MS disks./sticks, of any kind.
Ill pretend its still 100% HP, (be wise)
if that fails F11 that means the partition is damaged, (file or hdd bad)
run HDD tests yet, not just simple chkdsk?
there are only 3 cures, possible.
1: F11, (fails you said) but not clearly. read page 10 yet????
http://h10032.www1.hp.com/ctg/Manual/c03255541
2: HP, media kit buy it and load fresh, HP W7,
both fail if HDD is bad, testing any HDD is a long process.
using powerful HDD test software. can take a day to run that..
and the horror way.... (I do it all the time but am READY)
3: use Microsoft, W7 install media and then all HP drivers are dead.
but can be fixed, if time is not money.
what I do is move the HDD to a real DT PC. Desktop)
and plug it in say as drive E: (using adaptors , have them all I do)
then test it 100 %using powerful HDD tests. and powerful A/T scans. from Eset.com
Im not listing 100s of programs that do that, there are endless eon,s
use a non destructive tests.
run crystal-disk SMART yet?, to see if HDD is end of life ?
no spare , sectors is that, END OF LIFE>
the PC had a 500GB hdd.
why not get a new SSD and end this.
bet the media kit and move on
(if backed up , are you,) that be first, (ask or google that)
here is your support page
https://support.hp.com/us-en/product/hp-omni-120-1100-desktop-pc-series/5186992/model/5202640/product-info
here is the media kit,
Id get this , and keep if for life of PC, be best.
not one HDD lasts for ever, we plan ahead to be ready when it dies. as all DO. Be like boy scout,?
HP has best support of any company, no , im not HP, im retired, non HP, if you want to leave HP support, say so and we can talk all day on that, ..
MEDIA KITS:"
https://support.hp.com/us-en/document/bph07143
Jun 11, 2017 | HP Omni 120-1125 20" All-in-One Desktop PC
1,699 people viewed this tip
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
