Tip & How-To about Computers & Internet
How to Speed up a Slow Mac
Apple Mac computers can also become slow and sluggish with time and use. So here I will show you four methods to speed up your old-slow-mac.
Method 1: Free up hard drive space
You might have stored many huge video files, thousands of photos and music tracks on our Mac computer. The popularity of using solid-state drives (SSDs) of Mac computers means considerably less capacity than traditional hard drives.
1. Find the large media files on your Mac, delete the unused videos, apps, photos, etc. Or you can move all of them to an external hard drive, and remove them from your Mac.
2. Empty your trash cans, say the user account's main trash can and the iPhoto/iMovie/Mail trash can.
3. Remove junk files from your old Mac, MacClean is the way to go. It helps removing Internet junk, user junk, system junk and application junk on your hard drive.http://www.imobie.com/macclean/
Method 2. Free up more RAM
Most Macs ship with between 4GB and 16GB of RAM. If your Mac has only 4GB or 8GB RAM, the system might be running low when launching programs or loading document.
Step 1. Open up Terminal: ~/Applications/Utilities.
Step 2. Enter the command: Purge, and tap the enter tab.
Step 3. Give your Mac a minute or two to complete the process.
Open up Activity Monitor to see the before and after results, you'll find the Free size increases in System Memory.
Method 3. Kill Unwanted login items
Step 1. Open up System Preferences, and click the Users & Groups.
Step 2. Click the Login Items tab, and you'll see a list of apps that open every time you turn on Mac.
Step 3. Select the login items you want to kill, and click the "-" button to remove them.
Method 4. Clean up your desktop
1. Delete the files you don't need any more, and empty the Trash.
2. Classified the files on your mac, and move them to some folders.
3.Name the folder so that you can easily find the one you need. Why Is My Mac So Slow and How to Fix It
Computers & Internet Logo
How to fix a slow Mac? My MacBook is getting slow recently, how to speed up it?
there are many reasons about why your Mac works slowly. you should firstly clean it up. here is article which talks about how to speed a Mac you may need: 11 Methods to Speed up Your Mac
Jun 25, 2015 | Apple MacBook Air
Does Mac defragmentation help to speed up performance?
Defraging the hard drive will speed up file access because the files will be contiguous and the hard drive read/write head/s does not have to skip all over the disk to retrieve the files.
As for speed increase there will be some imrovement.
Installing more RAM will also speed up your computer.
Feb 06, 2013 | Computers & Internet
Mac G4 Running Slow
Many many reasons may be causing your Mac computer running slow, but generally two factors: hardware part & system part. For hardware part: I guess it's OK if your Mac is not that old. For system part: there might be a lot of junk files, caches, registry errors... out there which largely slow down any Mac machines. about 80% slow Mac caused by this reason, if so, try cleaning the system. Learn more from: http://www.howtospeedupmac.com/
Jul 22, 2010 | Apple Powerbook G4 15" Screen Mac...
slow mac computer
Generally, there are a couple of reasons that may cause a Mac computer running slow, but generally two factors: hardware part & system part. For hardware part: I guess it's OK if your Mac is not that old. For system part: there might be a lot of junk files, caches, registry errors... out there which largely slow down any Mac machines. about 80% slow Mac caused by this reason, if so, try cleaning the system. Learn more here: http://www.howtospeedupmac.com/
Sep 12, 2009 | Apple MacBook 13"White /2.0Ghz Intel Core2...
MY MAC LAPTOP IS RUNNING KIND OF SLOW- I DO NOT KNOW HOW TO CLEAN
Well, generally speaking there are a number of reasons that may causing a Mac computer running slow, but commonly two factors: hardware part & system part. For hardware part: I guess it's OK if your Mac is not that old. For system part: there might be a lot of junk files, caches, registry errors... out there which largely slow down any Mac machines. about 80% slow Mac caused by this reason, if so, try cleaning the system from: http://www.howtospeedupmac.com/
Jan 17, 2009 | Apple iBook G4 1GHz 256mb 40GB Combo 14"...
1,819 people viewed this tip
David Payne
David Payne
