Tip & How-To about Creativity Street® Scrapbookin Kids Class Pack 1 KT 1738
Sharpen your craft scissors
Take a piece of foil, folded over several times. Get your craft scissors, the ones with the different designs and cut through the foil, several times. This will help to keep them cutting, unless they have gotten to dual ...but you can try it. Thanks
Creativity Street® Scrapbookin Kids Class Pack 1 KT 1738 Logo
What is a craft knife?
You use this instead of scissors when making craft projects. It is used to make precise and detailed cuts on paper or cards. You should always use it with a cutting mat to protect your table and to protect the knife's blade.
Jan 17, 2013 | Office Equipment & Supplies
uniden dect 6.0 blank screen problem , the screen is completly blank but the phone functions properly I just can't see anything because its blank
I'm having the same problem as you are. My screen went blank for no apparent reason. I've been searching for a quick fix solution but I keep comming across asinine answers that has nothing to do with the original problem such as this one. If you find a solution before I do, can you please post it? Thanks in advance!
Oct 14, 2011 | Uniden DECT 6.0 Cordless Phone ID
How to reset the 'toner out' message in the Canon MF4350d laser printer?
This problem bugged me for months! Selecting CONT. PRINTING as indicated by Small6363 allowed to print with the warning light on but did not solve the warning light problem. I eventually found a way to bypass the flashing light and warning message.
Underneath the cartridge, on the cylindrical portion, in the middle there is a small flat rectangle. This is the ink level detection spot. Cut a piece of aluminum foil of the same size and place it with a piece of scotch tape overt that flat rectangle. Voilà! No more flashing red light and no more out of toner message! Of course you have to monitor your level visually and change the cartridge when printing starts to fade.
Hope this helps!
Patrick
Dec 02, 2010 | Canon imageCLASS MF4150 All-In-One Laser...
385 people viewed this tip
Top Creativity Street® Home Experts
john h
Tom Chichester
Are you a Creativity Street® Home Expert? Answer questions, earn points and help others
