Tip & How-To about Polaris 280
Proper Hose Length Sizing for Swimming Pool Pressure Cleaners
Belive it or not... too many swivels add to the problem!
Most people think if I add a swivel right here, where it begins to coil then tangle, it will fix the problem, but yet the problem remains!!!
The manufacturer recommends this for the proper layout of the hoses; from the wall all the way to the head:
If the hoses are old, they may no longer be pliable enough? You should replace them with new ones: 1 section Clear Soft Hose, and 2 sections of White, not so soft hoses.
  • First, determine the deepest part of the pool/pool "Depth"
  • That is how "Long" the 1st hose is to be. The softer clear hose
  • Now... Attach all the hoses together, 1st hose already cut per the above and the other two "White" hoses - UNCUT.
    • Place the head at the point on the deck where the wall adaptor is for the hose to attach
  • Walk around the pool holding the wall adaptor
    • Move your hand forward towards the edge of the pool to mark the total length of the pool, if you come to a point where your hand is over the water, hose is too short, move your hand back, if your hand is too far back away from the waters edge, the hose too long
  • Once you get back to the starting point, you should now know how long the hose needs to be. You could probably have 1' - 4', maybe more maybe less? Take note of the excess hose, that will need to be cut off, too long of hose will only tangle up. BUT WAIT, THERES MORE....
    • You may think that I now just cut off the excess length? You would be wrong!!!
    • Lets say you have 4' of excess hose...
    • Follow the hose in your hand to the next swivel, disconnect it.
    • NOW Cut. But... cut off 2' from one of the white hoses, AND 2' from the other white hose.
    • Reconnect the swivel. You have now cut off 4' of excess hose.
Recap: What you have done is with the 3 pieces of hose is cut it & adjusted it to the correct lengths. The soft hose is as long as the pool is deep. The two White Harder pieces are Exactly Even!! The way it should be!
Now, the Back up valve will be placed on the soft hose about 3-4' away from the head.
Follow this and the hose should not tangle. And...
Heed any advice about storing the hose coiled as it is not good, As this advice will be ABSOLUTELY CORRECT!
Whenever storing, always store in a straight line, otherwise it will retain the memory of the coil. If this has already happened, then take hose & stretch over the deck in the sun for the better part of the day, this will relax the hose & erase any memory of the coil.
Good Luck
Polaris 280 Logo
How do you replace a vacuum hose on a Riccar upright Vacuum.
Riccar Tandem Air models have a hose that has releases to push to remove the hose. Most Vibrance & 8000 series and older series vacuums have the hose attached to a swivel on the back of the vacuum. The hose can be unscrewed from the swivel. To remove the swivel you need to remove the vacuum bag inside the dust compartment, you must compress the tabs holding the swivel to the body to be able to pull it out.
Aug 08, 2016 | Riccar Vacuums
How do I remove the swivel neck assembly from the vacuum case?
You will also need to remove the screws on the inside that hold the motor in place because part of the side support for the swivel is under the motor. Remember to disconnect wires coming from the swivel as well before you try to pull it out, so that you do not damage them. Hope this helps.
Jul 16, 2014 | Windsor SR12 Sensor Bagged Upright Vacuum
My swivel sweeper handle snapped right off where it is supposed to lock in place. Do they offer replacement for this?
You would need to check with the company where it was purchased. Some merchants just 'even-exchange' if you bought from a local retailer. Depends also on model/price. If it is lower-end item to begin with, may not be worth your trouble.
Sep 23, 2013 | As Seen On TV Swivel Sweeper Vacuum
Assemble Swivel Assembly onto Kenmore Canister vac
Got this post off this web site...I just replaced my swivel and it worked:
http://www.managemyhome.com/mmh/answers/Answers.action#l4q110567
To install a new swivel assembly, you will need 2 small, flat tip screw drivers. Unplug the vacuum. Push the screw drivers in between the hose and the collar where you see the seams in the plastic collar on the end where the hose enters the collar. This will release tabs that hold the collar to the swivel. Pry and pull the collar back over the hose and then pull the small screwdrivers out of the collar. Slide the collar back along the hose. Unplug the wiring connections from the hose. Pull the hose wires up and out of the holder on the swivel assembly. Lift the tabs on the side of the hose and pull it off of the swivel. Push the new swivel onto the hose. Align the hose wires and secure them in the holder. Plug the wires from the swivel into the hose wires (blue to blue, white to white). Secure the swivel wires into the wire holder on the swivel assembly. Push the collar back up the hose and onto the swivel with the plastic seams aligned with the tabs on each side of the hose. Snap the collar securely into place.
Nov 12, 2008 | Kenmore 25512/ 25513 Progressive Canister...
358 people viewed this tip
Top Polaris Vacuums Experts
JoeVacs
Are you a Polaris Vacuum Expert? Answer questions, earn points and help others
