Tip & How-To about Music
How to de solder
A common electronics problem is a Blown or Burnt up component
a lot of times you don't need to know about electronics to diagnose this as a problem
it will be a visual thing that you can see, like a burn mark on the circuit board
anyways if you can solder you should know or learn how to de solder
its much better than trying to clip leads and solder to them when replacing parts
I always de solder a part that need to be replaced
for some reason I cant upload photos to fixya ?
im one of those tech geeks that doesn't own a computer...
just an android phone and an iPod
so BELOW is a Link... for a video GIF of the process I explain
First Make sure the amplifier or equipment you are working on is Unplugged !!
and capacitors are discharged !!!
then I remove the circuit board after careful inspection
pre heat de soldering iron
carefully heat the area of the component to be removed
i wiggle it back and forth a little and from side to side
pre press in the solder extractor before heating the area
once the area becomes non solid let go of the extractor and the solder will
be sucked up into the iorn
then i use a tin foil pan to press it out repeat untell the part is loose and removable
sometimes you have to wiggle the part a little while heating to help it out
then i clean up the pad area where the New component is to be reinstalled
do this Carefully you do Not want to damage the pad
now ready for the New part
I really hope this Helps someone out, as for there was Not much help for me in the beginning 40 years ago...
as always thanks for your time, and check back for more tios to follow....
de soldering
https://plus.google.com/110306910392117218371/posts/d3Ek2MBRuYP?pid=6125577609843825250&oid=110306910392117218371
Music Logo
How do I fix a blown op amp on fender hot rod deville 2x12?
Unless the person that analyzed this problem used an oscilloscope and did detailed troubleshooting, I would NOT jump to the conclusion that aan op amp was blown BASED upon my looking at the schematic of the unit. There are MANY components involved with the overdrive channel, including relays and other transistors and components. The most probable caause would be that 1/2 of the V2 vacuum tube is burnt out. Test by swapping V1 with V2. If NOTHING works, then replace the tube that is NOW in V1 as the second section of it has a burnt out heater. Also a bad potentiometer for the OD channel would be a suspect. A VERY common problem is broken solder at pot terminals. Try plugging a set of headphones into the preamp output. See if you can hear sounds in bothe OD and clean channels. Note you will only hear sound in the LEFT headphone as the preamp out is MONO. MOST of the three op amp chips would NOT kill the OD signal if they were bad.
Sep 04, 2012 | Fender Hot Rod Deluxe Guitar Combo...
Keyboard not powering up. Want to change the fuse/s. Don't know where fuse is located.
There probably is NOT a fuse and usual cause is problem with the adapter or the power connectors. Broken solder of the connector in the keyboard is common. Broken cords on the adapter is common as well.
Oct 29, 2011 | Casio Ctk 496 Electronic Keyboard with 61...
is burning my component, I need trasistor M50D060 s thank you
You have bigger problems than just the IGBT. I replace that part with part number:
APT28GA60BD15
About $6.50 from Digikey.com
You will probably find one or both of the gate speedup diodes blown PN DL4148 surface mounted an one or more of the driver transistors 2SSA1020-Y and 2SC2655-Y blown and usually the IR2153 switching regulator chip. If you haven't blown the 10 ohm ceramic pre-charge resistors you are lucky. Put a 150 watt lamp in series with the power cord to save fuses and parts till it is repaired. If you don't have schematic get back to us.
Aug 29, 2011 | Behringer Pmp3000 16 Channel Audio Mixer
I have a KPM 4080 mixer that has a blown 1A fuse. What would be the most common cause.
The most common cause of a fuse blowing is excess current... now what has/could cause that is impossible for us to diagnose remotely. Failure in the power amp would be prime suspect with power supply components a close second. Double check that fuse rating... if on 120 volts it sounds low... it would be right for 220 operation.
Jun 04, 2011 | Kustom KPM4080 PA Amplifier/Mixer
My keyboard keeps shutting off within a minute or two of playing. The woman I purchased it from told me that it had an auto-off battery saving mechanism if you don't touch a key for a while, but this isn't the case with my keyboard. It's shutting off while playing. And, I can't see the display when I'm standing up over it. Only while I'm sitting down playing.
If you are running on batteries, they are either depleted OR may have corrosion on the contacts in the keyboard which is COMMON problem. If using an adapter, the cords chronically work loose. A last problem is the switching for using battery or adapter can have poor contacts. If you don't have an adapter, get one and get one SPECIFICALLY for the keyboard... I don't know how many I have had to tell they have the wrong adapter and that is why their unit won't work.
May 15, 2011 | Casio CTK-720 Electronic Keyboard with...
227 people viewed this tip
Top Music Experts
Vito Vacirca Jr.
Are you a Music Expert? Answer questions, earn points and help others
