Tip & How-To about Stairmaster 4000PT Stepper
How do I test for continuity of the gray cable on my Stairmaster 4000PT?
Testing for Continuity of the Gray Cable on a Stairmaster 4000PT
  1. First disconnect the grey cable from the back of the console and UNPLUG YOUR MACHINE from the wall.
  2. If your cable has a 6-pin round connector, you will need to check pin sockets #5 (black wire), #3 (blue wire), #2 (brown wire) and #4 (white wire) with your ohmmeter for continuity in each pin. Should get continuity from all if cable is good.
If your cable is a 9-pin cable, you will need to check pin sockets #5 (blue wire), #3 (black wire), #2 (brown wire) and #4 (white wire) with your ohmmeter for continuity in each pin. Should get continuity from all if cable is good.
http://www.sportsmith.net/faq.aspx?did=36FBE6B5-B902-41E0-891D-11B48E2E92ED
Stairmaster 4000PT Stepper Logo
StairMaster 4000PT console gets pixalated, machine freezes after 15 minutes of working out
This really still sounds like a console issue. You can check your load resistor just to make sure that is not causing an issue. It should be labeled as to what ohms it is rated as. Simply unhook it and, using a multi-meter, check the ohms. It should be +or- 10%. I am attaching a link to a video on how to use a multi-meter just in case.
Video about Multimeter Testing
Mar 31, 2014 | Stairmaster Exercise & Fitness
why does my stairmaster 4000pt randomly shut off
Replacement Parts for Fitness Exercise Equipment at SPORTSMITH
Check continuity of the console cable. If this checks out, open the console and look for any corrosion on the circuit board. If this seems to be the issue, you will have to find someone to repair the circuit board as they are no longer available.
You can find more parts for the 4000PT at the following link: Stairmaster Stepper 4000PT Parts Power Supply Spring Hub SPORTSMITH net
Mar 13, 2013 | Exercise & Fitness
need battery, 4000PT
If you have a 4000PT, chances are, you do not have a battery. This machine requires and external power supply. These can be viewed on our Website. Stairmaster Stepper 4000PT Parts Power Supply Spring Hub SPORTSMITH net
Oct 11, 2012 | Stairmaster Remanufactured (4000PT)...
298 people viewed this tip
Top Stairmaster Exercise & Fitness Experts
Sportsmith LLC
Sportsmith LLC
Matt Olenzek
Matt Olenzek
zr800o1le
zr800o1le
Level 1 Expert
Are you a Stairmaster Exercise and Fitnes Expert? Answer questions, earn points and help others
