Tip & How-To about LeMond Bicycles Cycling
Tip for Easy Installation of the Bottom Bracket Spindle Shaft for a LeMond RevMaster Classic
When installing a new bottom bracket spindle shaft onto your LeMond RevMaster Classic indoor cycle, it is important that you note which way it is to be used by looking at the spindle closely. We've learned a tip that makes for easy installation and that is a quick measurement will determine the proper orientation of the spindle.
  • The spindle has different lengths from the edge of the raised portion to the ends.
  • The measurement of roughly 1-3/4" will be on the RIGHT side and will attach to the RIGHT crank.
  • The opposite side measures roughly 1-1/2" from the end to the edge of the raised portion, it will attach to the LEFT crank arm.
Easy Install Tip for Bottom Bracket Spindle Shaft to LeMond RevMaster...
Cycling Logo
i cant get the front hub assembly off my 03 buick rendevous
Items/Tools needed:
35mm or 1 3/8" axle socket
3/4 or 19mm socket for lug nuts or lug wrench
15mm socket for brake caliper and bracket
13mm socket for wheel bearing bolts (extentions as well)
Breaker bar or impact wrench to remove lug nuts and axle nut (Note: Do not use impact driver to install axle nut).
Torque wrench for axle nut
Hub puller - Optional
Hammer
Directions
1. Jack the appropriate side of the car up. Make sure the rear wheels are blocked and/or set the parking brake. Use a jackstand to support vehicle at subframe for safety.
2. Remove wheel.
3. Remove brake caliper and bracket.
4. Remove rotor.
5. Using 35mm axle socket, remove axle nut, turn counterclockwise. You will either need an impact or a long breaker bar. They are installed with a lot of torque or may be rusted out or corrroded.
6. Push the axle back as far as possible. It won't come all the way out or through the hub, but will become loose. You can either get a tool that will push it out like a hub puller, or just use a hammer making sure not to hit the axle shaft threads and damage them. Put the axle nut back on the axle shaft so it is flush with the top. Then place 35mm axle nut socket on the axle nut and tap on the 35mm socket with the hammer not the threads on the axle shaft spline.
7. Disconnect the wheel sensor connector and then remove hub side connector from the bracket (unclip).
8. Take a 13mm socket with extensions as needed and remove the 3 bolts on the backside of the bearing around the axle. Be sure to use PBBlaster to help loosen the bolts.
9. The hub/bearing should come loose without need needing a hub puller. Be sure to note the sheet metal spacer between the hub and spindle with also has the bracket for the wheel sensor connector.
10. Double check both parts (hubs) to make sure they match.
11. Lube the axle shaft splines with good quality bearing grease before installing the hub. Clean off any old grease and crud first.
12. Install the hub assembly with the wires from the bearing at the bottom. Line up hub splines with axle shaft splines and push in on hub. Note: Don't forget that sheet metal plate between the spindle and wheel bearing. Note: Make sure the wheel sensor wires don't get pinched by the axle shaft.
13. Install the 3 13mm bolts to 96ft lbs. Service manual recommends replacing with new ones. Some hubs like AC Delco will come with new bolts which have threadlocker.
14. Install the axle nut. As tightened down it will pull the driveshaft the rest of the way in. Torque axle nut to GM specs of 159 ft-lbs or the figure specified by the hub manufacturer. It is recommended to use a new axle nut but not necessary.
15. Install the rotor, brackets and caliper. Torque caliper bracket bolts to 137 ft-lb and caliper pin bolts to 63 ft-lb.
16. Install the connector to the sheet metal bracket and reconnect both connectors.
17. Install the wheel. Torque lug nuts in a star pattern at 100 ft-lbs each.
18. Road test car and ensure any ABS and TRAC OFF light are off.
Sep 18, 2011 | 2003 Buick Rendezvous
217 people viewed this tip
Top LeMond Bicycles Cycling Experts
Michial Gueffroy
John Egan
John Egan
Are you a LeMond Bicycles Cycling Expert? Answer questions, earn points and help others
