Tip & How-To about Exercise & Fitness
How To Re-Wax a Wood Deck for a Trotter Treadmill
Following are instructions on how to re-wax a wood deck for a Trotter treadmill and a list of materials needed for this procedure
Materials Needed for Re-Wax
  • 1 lb. of Trotter deck wax
  • Clothes iron (never to be used on clothing again)
  • Belt sander with 120 grit sanding belt
  • Vibrating sander with 250 and 400 grit paper
Pre-Existing condition: If your wood Trotter treadmill deck is worn down through the first ply, it cannot be re-waxed.
  1. Using a belt sander and 120-grit belt, gently sand in the same direction as the grain the glazed layer off the top of the deck until you have reached porous wood. If, while sanding, the first layer of ply has been sanded off, the deck can no longer be re-waxed
  2. Using a vibrating sander with 250-grit paper, sand the entire top surface of the deck until it is smooth and soft.
  3. After sanding with the 250-grit paper, continue sanding with 400-grit paper until completely smooth.
  4. Heat the clothes iron to its maximum temperature. Put a handful of Trotter deck wax on the center surface of the deck and place the preheated iron on top of it until the wax melts.
  5. Work the wax into the deck surface by pushing the melted wax across the deck with the iron. Add more wax as needed until the entire top surface of the deck is impregnated with wax.
  6. Apply just enough wax until the wood is saturated with wax.
Do NOT leave wax pooling on the surface of the deck.
How To Re Wax Wood Trotter Treadmill Deck
Exercise & Fitness Logo
cybex 520t error 6
Replacement Parts for Fitness Exercise Equipment at SPORTSMITH
Error 6 is a motor over voltage error. Motor voltage exceeded 200 VDC for 200 milliseconds. This can be caused by a worn deck and belt due to a lack of routine maintenance. AKA adding wax between your deck an belt. You might be able to wax your machine and make the error go away. More than likely a new deck and belt will be needed. Using the link below and your model and serial number, you can find the needed items. In worse case scenario, you may also need a new motor control board.
Repair Parts for Trotter Cybex Treadmill 400T 410T 500 Series SPORTSMITH...
Apr 07, 2014 | RTO Cybex 520T Remanufactured Treadmill
lubricating walking belt
Video about How to Wax a Treadmill Using Powder Wax
How to Wax Treadmill Using Powder Wax Video
Video of How to Lubricate a Treadmill using Liquid Lube
How to Lubricate Treadmill Using Liquid Lube Video
Apr 02, 2014 | Exercise & Fitness
cybex 530t error 6
Jan 20, 2014 | Exercise & Fitness
change a treadmill belt
Check the video which will help you do the same. All most all treadmill follows the same procedure.
Dec 15, 2012 | Treadmill Doctor Cybex Trotter400t 410t...
367 people viewed this tip
Top Exercise & Fitness Experts
Howard
Howard
Sportsmith LLC
Sportsmith LLC
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
