Tip & How-To about Exercise & Fitness
Identifying Your Reebok / Robix Studio Cycle
  • 9600
    Black matte finish on 1-piece welded frame. Black crank arms (generally) and dual brake pads.
  • 9800
    Black matte finish on 1-piece welded frame. Black crank arms (generally) and single brake pad.
  • 9900
    Glossy finishes w/angled back legs (stabilizer). Bolt-together frame (assembly required). Rectangle shaped stabilizers.
  • 2000B
    Glossy finish w/angled back legs (stabilizer). Bolt-together frame (assembly required). Oval shaped stabilizers and single brake pad. Silver crank arms and belt driven.
  • 2000C
    Glossy finish w/angled back legs (stabilizer). Bolt-together frame (assembly required). Oval shaped stabilizers and single brake pad. Black crank arms and chain driven.
  • 3000B Robix
    Black glossy finish w/angled back legs (stabilizer). Bolt-together frame (assembly required). Oval shaped stabilizers and frame down tube. Belt driven with single brake pad.
http://www.sportsmith.net/Categories.aspx?did=CEF96124-843A-4128-9B53-8E10980C9920
Exercise & Fitness Logo
PANDIGITAL PHOTO FRAME
1. Remove the backing board and matte from the traditional frame, being careful not to get fingerprints on the glass.
2. Most likely, the cutout of the matte will be slightly wider than your digital frame's screen. If this doesn't bother you, skip this step. Otherwise, have a matte custom cut with an appropriately sized inner opening. (For the 8-inch Nixplay Edge, this is 6? by 4? inches.)
3. Place small pieces of poster putty on the front corners of your digital frame (see figure A). Then place the back of the matte gently on top of the screen. Adjust as necessary to align the screen. Then press firmly on the corners.
4. Secure the digital frame to the matte with pieces of wide masking tape.
5. Set the matte and screen into your traditional frame. Insert four frame spring clips (available at americanframe.com and some custom framing shops) to hold everything in place (see figure B).
Jul 17, 2016 | Photography
I have a Epson pro large format 9600, I print on canvas, I have use Photo black since I have it, but never getting a saturation ressult. I have been counsil by Epson to use Matt black rather than Phot
"Photo black" is designed specifically for glossy photo paper. Matte black is for non-glossy paper, including plain paper. Matte black will print darker on non-glossy paper than photo black does.
Oct 28, 2014 | Epson Office Equipment & Supplies
The left arm of the cranck don't come out,so i can't take the cranckset off the bottom bracket.Every bolt it's already untight. Thanks!! Stefano
There are 3 bolts to remove: 1 the main large cap in the center of the arm, and 2 bolts holding the arms in place. Remove all three completely. If the arm still will not come off easily, then take a large screwdriver and work in between the bearings and the crank arm and gently pry off.
The trick is too only move a little then go to another section and move another small amount. until the crank arm wants to loosen. The most likely culprit is a small black piece of plastic that is holding up the works.
Nov 23, 2010 | Shimano XTR Hollowtech II Mountain Bike...
black and decker model 7404 1/3 sheet sander - not orbiting
wear inhibitor part number 86355 has broken on you. When this part brakes it brakes into tiny pieces which then leave the case so it hard to tell whats wrong. They don't make this part any more as the 7404 was discontinued in October 1975. I hoped this helped. I have the same problem.
Feb 07, 2009 | Black & Decker 7448 1/3 Sheet Orbital...
514 people viewed this tip
Top Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
