Tip & How-To about Exercise & Fitness
Tri Flex Deck Spring Bumper Kit Installation Instructions
Following are instructions on installing the tri flex deck spring bumper kit for the Quinton 3.0, Clubtrack, Clubtrack Plus, MedTrack CR60 and MedTrack SR60 treadmills.
  1. Set the treadmill to 5% grade and turn off the circuit breaker. Unplug the treadmill power cord from the outlet.
  2. Remove the front trim cover, hood, and both side rail covers.
  3. Relax the tension on the walking belt by removing the two screws in the rear end caps and the end caps.
  4. Remove the rear roller, then the front roller.
  5. Remove the walk belt and deck.
  6. Remove the compression mounts noting the position of the short and long mounts.
  7. Install the new compression mounts. DO NOT USE LOCTITE. Each side rail should have 5 long and 4 short compression mounts. The two rigid spacers will be installed in the rear holes.
  8. Install the slider bed (deck) and belt. Install the 12 6mm hex head screws using Loctite 242 on the threads. Torque to 30 inch-lbs.
  9. Replace the rollers, end caps, side rail covers, hood and front trim cover. Tension the walk belt and adjust belt tracking.
  10. Verify operation by operating the treadmill with a user at various speeds. Verify there are no unusual noises from the deck area .
http://www.sportsmith.net/page.aspx?did=01035F31-1611-489D-9B3F-E500A84EEC4F
Exercise & Fitness Logo
Code e207 stairmaster club track
Replacement Parts for Fitness Exercise Equipment at SPORTSMITH
E207 is an error indicating "Moderate Motor Overcurrent". This occurs when either the user is out of the maximum weight range or there is excessive wear on the deck or running belt. The following link will take you to the parts and other information we have available on the club track.
Stairmaster Quinton Treadmill ClubTrack 612 612 Parts SPORTSMITH net
Jul 08, 2013 | Exercise & Fitness
E203 error message when i press start button
Quinton E203 Error, Motor Overcurrent (Overload) Probable Cause 1. Obstruction to motor pulleys or belt
2. Disconnected or loose motor lead
3. User outside the weight/speed envelope.
4. Excessive wear to deck/belt.
5. Motor.
6. Lower Electronics.
Corrective Action Quinton Treadmill Models: Club Track 3.0 and Hyperdrive
  1. Inspect for obstruction and remove if necessary.
  2. If the motor did not turn, inspect for loose or disconnected motor lead. Reconnect if necessary.
  3. Restrict users to weight capacity of unit. Restrict use to people that do not move slower or faster then speed setting.
  4. Inspect deck and belt condition. Deck should have a slick smooth surface, free of nicks, grooves, or rough areas. Deck should be flipped or replaced if necessary. Underside of belt should not have a hard glazed appearance. Belt should be replaced when deck is flipped or replaced.
  5. Club Track 3.0 models: Remove power and allow unit to cool for 15 minutes. If unit operates and then error appears again, replace drive motor.
    Hyperdrive models: Remove power and wait for high voltage indicator to go out. Check resistance between motor leads. If the reading is greater than 100 ohms, the motor needs replaced.
  6. Club Track 3.0 models: Remove power and allow unit to cool for 15 minutes. If error message appears immediately, replace the lower electronics.
    Hyperdrive models: Remove power and wait for high voltage indicator to go out. Check resistance between motor leads. If the reading is less than 100 ohms, replace the lower electronics.
Quinton Treadmill E203 Error Code
Jan 09, 2013 | Exercise & Fitness
E203 error message on Quinton Clubtrack treadmill
Dear Sir:
Your problem is lack OF LUBE, do it in according with the instruction manual maintenance, is to due worn deck.
This produce enough friction between deck vs deck belt.
3) Test the input voltage for main motor if there are voltage motor need repair or replace.
4) Test the output voltage from main board, if there are NOT, the board is faulty.
5) Try to RUN the software calibration for diagnose and troubleshooting.
sincerely. God bless you
Apr 30, 2012 | Exercise & Fitness
quinton clubtrack treadmill shows E203 code, says drawing more than specified current. Could it be a bad motor?
5. Motor.
Dec 06, 2011 | RTO Stairmaster Clubtrack 510 Treadmill
I have a Quinton Clubtrack treadmill Error E105 NVRam Failure
fax me @ 281-469-9550 your full model number and I can fax you the setup modes.
Jun 27, 2009 | RTO Stairmaster Clubtrack 510 Treadmill
316 people viewed this tip
Top Exercise & Fitness Experts
Howard
Howard
Sportsmith LLC
Sportsmith LLC
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
