Tip & How-To about Quinton CLUB TRACK Treadmill
How To Calibrate the Lift Motor on Quinton ClubTrack Treadmill
The following describes the steps required to calibrate the lift motor on a Stairmaster (Quinton) ClubTrack.
  1. Enter service mode on the treadmill by using the following keys at the same time:
    • Faster - Slower - Stop Belt
  2. Allow the lift motor to free spin by removing the bolts from the metal block on the jack screw.
  3. Press the up arrow on the control panel until the incline is at 5% then press the down arrow and take it back down to 0%. This will allow the lift motor rheostat to find its range.
  4. Spin the metal block on the jackscrew to allow 1 - 1.5 threads to be exposed from the top. Secure the lift motor back to the frame by inserting the 2 bolts through the bracket holes and into the metal block. NOTE: Double check the spacers on each side to make sure they are flush.
  5. Run the treadmill incline up to 15% and check the jackscrew to verify it has not bottomed out before reaching 15%. There should be around 4 - 6 threads exposed. Bring the treadmill back to 0% where there should be the same amount of threads exposed from the top of the jackscrew. If you see the correct amount of threads the lift motor is calibrated.
NOTE: If there is an error on the display panel, ex. E211, you need to manually turn the jackscrew back to 0%. To perform this unscrew the 2 bolts from the bracket securing the metal box and jackscrew allowing it to freespin. Use a shop rag or towel to wrap around the jackscrew to prevent damage to the threads. Using a pair of pliers (channel locks or vice grips recommended) manually turn the jackscrew back to 0%. Once this is accomplished run through the above steps to perform the calibration.
Quinton Treadmill Support How To Calibrate the Lift Motor
Quinton CLUB TRACK Treadmill Logo
tc/tm config rqd 1 on 425 hr clubtrack plus treadmill not stair climber
Perform the following steps to configure the treadmill.
  • Enter the service mode
  • For the HR ClubTrack Plus, enter the configuration by using the menu choices on the service mode screen, which should be CP3 for the HR Clubtrack Plus.
  • Press SELECT  to store the configuration. (For the HR ClubTrack Plus, select the Set Screen Contrast screen and use the contrast up and down buttons to select the optimum contrast. Select Enter to save the value.)
  • Exit the service mode and confirm proper function of the treadmill.
Jun 20, 2015 | Exercise & Fitness
Code e207 stairmaster club track
Replacement Parts for Fitness Exercise Equipment at SPORTSMITH
E207 is an error indicating "Moderate Motor Overcurrent". This occurs when either the user is out of the maximum weight range or there is excessive wear on the deck or running belt. The following link will take you to the parts and other information we have available on the club track.
Stairmaster Quinton Treadmill ClubTrack 612 612 Parts SPORTSMITH net
Jul 08, 2013 | Exercise & Fitness
I have a quinton clubtrack treadmill with an E105 code
E105 means power interruption if this is a 3.0 or Hyper Drive just need to hit clear or start that should take of code until either it is unplugged another power outage
Mar 02, 2010 | RTO Stairmaster Clubtrack 510 Treadmill
I have a Quinton Clubtrack treadmill Error E105 NVRam Failure
fax me @ 281-469-9550 your full model number and I can fax you the setup modes.
Jun 27, 2009 | RTO Stairmaster Clubtrack 510 Treadmill
418 people viewed this tip
Top Quinton Exercise & Fitness Experts
Howard
Howard
Sportsmith LLC
Sportsmith LLC
Tom Chichester
Are you a Quinton Exercise and Fitnes Expert? Answer questions, earn points and help others
