Tip & How-To about Stairmaster 4000PT Stepper
Is there a Quick Test I can do when there is No Resistance on my Stairmaster 4000PT?
The following test will help to determine if the cause of no resistance on your Stairmaster 4000PT stepper is the console. By performing the following test, the console is eliminated from the electrical circuit. If resistance is present when the test is performed, the console is bad. Paper Clip Trick
  1. First UNPLUG YOUR MACHINE from the wall, then disconnect the grey cable from the back of the console.
  2. If your cable is a 6-pin round connector or a 9-pin square connector, using a paper clip formed into a "U" shape, insert the ends of the paper clip in the pin sockets #2 and #4. Then you will need to plug the power cord back in and start stepping. You should experience full pedal resistance.
  3. If there is still no pedal resistance, UNPLUG YOUR MACHINE from the wall and disconnect the wire from an end of the load resistor so that there is no wire attached to that end. Then plug the power cord back in and perform the paper clip test again. If resistance is present, the load resistor needs replaced. If resistance is not present, either the gray cable or the alternator is bad.
http://www.sportsmith.net/faq.aspx?did=88B6E8F1-92F8-4B60-8B2E-47911ADB84AA
Stairmaster 4000PT Stepper Logo
why does my stairmaster 4000pt randomly shut off
Replacement Parts for Fitness Exercise Equipment at SPORTSMITH
Check continuity of the console cable. If this checks out, open the console and look for any corrosion on the circuit board. If this seems to be the issue, you will have to find someone to repair the circuit board as they are no longer available.
You can find more parts for the 4000PT at the following link: Stairmaster Stepper 4000PT Parts Power Supply Spring Hub SPORTSMITH net
Mar 13, 2013 | Exercise & Fitness
need battery, 4000PT
If you have a 4000PT, chances are, you do not have a battery. This machine requires and external power supply. These can be viewed on our Website. Stairmaster Stepper 4000PT Parts Power Supply Spring Hub SPORTSMITH net
Oct 11, 2012 | Stairmaster Remanufactured (4000PT)...
stairmaster 4000pt pedal slips
Why does one pedal drop on my Stairmaster Stepper but the other pedal operates correctly? Stairmaster Steppers, How to Troubleshoot when one Pedal Drops (Loses Resistance) while the Other Pedal Operates Correctly
  • If one pedal drops while the other operates correctly on your Stairmaster stepper, this problem commonly occurs when the drive sprocket on one side or the other becomes defective
  • Usually, when one drive sprocket fails, the other isn't too far behind
  • The best approach to resolve this problem is to install a new hub assembly
Why does one Pedal Drop on my Stairmaster Stepper
Jul 07, 2012 | Stairmaster 4600PT Stepper
294 people viewed this tip
Top Stairmaster Exercise & Fitness Experts
zr800o1le
zr800o1le
Level 1 Expert
fordexpert
Matt Olenzek
Matt Olenzek
Are you a Stairmaster Exercise and Fitnes Expert? Answer questions, earn points and help others
