Tip & How-To about Ematic 7" Tablet Computer
Reset Ematic Password
NOTE: This will erase everything from the tablet and reinstall its operating system to factory default. This is the only way to get passed the password if you forgot it.
1). Make sure the tablet is off.
2). Press the and hold the POWER BUTTON the obediently press and hold the BACK BUTTON.
3). Continue holding BOTH buttons until the Emetic logo appears. The release only the POWER BUTTON continue to hold the BACK BUTTON until the android with open door and menu appears.
4). Select "WIPE DATA/FACTORY RESET"
5). A list of several "NO.." will appear, scowl down and click on the only "YES.."
6). With the "Yes.." Highlighted in a blue bar press the "POWER BUTTON" one time.
7). The system will format and restore the operating system.
8). Select "REBOOT SYSTEM".
9). You should be good to go.
9). You should be good to go!
Ematic 7" Tablet Computer Logo
Want to erase password and start over
n order to reset to factory settings, please follow these instructions :
- Power off machine.
- Hold down + first and then POWER for about 10 seconds, release both buttons once Kurio screen loads .
- When you get the open Android picture, press + to enter menu, use - to move down to "wipe data / factory reset" and press POWER again to choose.
- Next press - to choose "YES" and press POWER to start reset.
- Check for yellow text Formatting /data, formatting cache, Data wipe complete.
- Choose reboot system now and press POWER to complete process.
NOTE: This will erase data from your Kurio's internal storage such as Accounts, System settings and Downloaded apps. But music, pictures, and other user data won't be erased. Check "Erase SD card" if you want to clear all the data of the system.
It is also possible to reset only the Kurio Interface: Go to Parental area > Tablet Setup> Press "Reset the Interface to Factory Default Settings".
Once this has been done you will need to set the device up and perform all the updates, instructions for this are on this page.
Mar 04, 2015 | Kurio 7S Tablet
How do I reset my digital2 8" tablet
Depends on the model number.
I found this.
" Click "Settings" ? "Backup & Reset" ? "Factory data reset" to clear all user setting and recover the system to the default status.
Please kindly be noted that some models (like D2-711) may require extra step as to select reboot system now.
(Note: All installed applications and user personal data will be erased (emails, contacts...etc.). Data saved in the internal storage like photos, music files and others will not be erased.) Make sure to back up all your files first."
Dec 19, 2014 | Digital2 Tablets & eReaders
my tablet wont pass the prestige elite screen, what do I do?
Try this, hold down the power button, and the
Volume down buttons at the same time. Keep holding
Until you see a 3d android, lying on it's side.
Then use the volume down button, scroll down to either,
system reboot. Or factory reset ( if you have an SD card in, take it out first)
The reboot will just reboot your tablet, and it should
Turn on and fix the problem.
the factory reset, will erase everything in the system.
If it ran alight before, and you had stuff saved to the
Tablet, it will erase it also. I'm sorry but it can't be saved.
so make sure your SD card is not in.it will erase it too.
The factory reset will restore the tablets settings, and reboot. But only do this as a last resort. Hope this helps
Aug 23, 2014 | Tablets & eReaders
How do i reset my asus tablet
Step 1. In the device,select settings on the application list >select back up and reset >factory data reset >reset tablet >erase everything. step 2 . The system will erase all user data and reboot automatically. Please note all data will be erased from tablet!!! 12_22_2013_7_37_26_am.png
Dec 17, 2013 | Tablets & eReaders
How to reset Pandigital 7 in. Planet Tablet to factory settings?
There are two ways to do it. You can either update the firmware and it will erase everything for you, or you can do a factory reset, and return to factory settings. Go to Settings, PDN settings (not the Android settings menu) and scroll right to the Reset Defaults location. Tap on the reset button and you will be taken back to factory default settings. It might take a while to reload, but after everything it will be back to factory defaults from when you first bought it. Updating the firmware might be your best option if you care to resell it, because it may cause less issues for the next person and less chance of any returns.
Oct 17, 2011 | PANDIGITAL Digital Book 843967071153...
1,606 people viewed this tip
Top Ematic Tablets & eReaders Experts
Ap12
Ap12
Michael Harrier
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you an Ematic Tablet and eReader Expert? Answer questions, earn points and help others
