Tip & How-To about Lenovo S5000 7" Android 1GB 16GB
DISASSEMBLING AND CHARGER CHECKING
LENOVO S5000-F - S5000-H
Checking the Computer AC Charger
When you use the computer AC Charger to charge the tablet but no power is charged, see the instructions in this topic to check the computer AC Charger.
To check the computer AC Charger, do the following:
1. Disconnect the micro-USB cable from the tablet.
2. Measure the output voltage across the connector marked B of the micro-USB cable. Refer to the following figure:
For more pictures and description check the link bellow. On search tab type Lenovo
www.electro-medical.blogspot.com/
google.com/+AjinGopakumar
Lenovo S5000 7" Android 1GB 16GB Logo
how to replace charger port on Lenovo tablet?
has to be sent in to a repair shop .check with Lenovo as to where they might be Official Lenovo Support Home Lenovo Support US
Aug 14, 2015 | Lenovo ThinkPad X60 Tablet PC
how do I get my tablet to turn on
It sounds like it may not be fully charging.
If the port on the tablet is loose/damaged or the cable/charger is failing, then the tablet may not be charging even though its plugged in.
If you can, try a different cable.
Make sure the charger is the correct one for the tablet! Some tablets require more electrical current then a computer's USB port provides. Same thing applies if you are using a 'phone' charger with the tablet, might not be enough current.
Most USB ports/chargers output about 5 volts DC (direct current), but they can vary in the amount of Amps (A) or mili-Amps (mA) they produce.
FYI - the symbol used to represent Direct Current is straight horizontal line with a dashed horizontal line directly under it.
Most computer USB ports only produce 500mA.
Most phone chargers only produce 1A.
Many tablets require 2.1A or 2.4A to properly charge.
Check with your tablet manufacturer to find out what your specific make/model requires and the look closely at the charger you are using to see what the OUTPUT is ... e.g. 5.2V 2.4A
Mar 29, 2015 | Lenovo S5000 7" Android 1GB 16GB
proscan 7044K-C tablet won't charge
Test your charger with a multi-meter, does it output the correct supply? If not you need a new charger.
If your charger is ok, take a look at the charging socket, is it damaged in any way? Does the charger feel loose when it's plugged into the socket? If so you may need to have your charging socket repaired/replaced.
After checking all this the next thing I would try is a new battery. However, most tablets will at least work from main supply, even if the battery is faulty.
Mar 21, 2014 | Tablets & eReaders
how long should I leave my kindle plugged into charger
From a guess,about an hour.But keep checking on it.
Mar 17, 2012 | Amazon Kindle 2
1,155 people viewed this tip
Top Lenovo Tablets & eReaders Experts
vojvodabudva
Are you a Lenovo Tablet and eReader Expert? Answer questions, earn points and help others
